e-brake adjusting rear brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by newtotacos00, Jan 8, 2018.
  1. Jan 8, 2018 at 7:03 AM
    newtotacos00
    newtotacos00 [OP] New Member
    kenny
    2001 toyota tacoma
    recently i noticed the rear passenger side tire locking up on my 01 tacoma v6 4x4. i took off the rear wheel and the drum was stuck so i knew the shoes were open more than they should be. upon closer inspection i noticed when i moved the e-brake mechinism it turns the brake shoe adjuster which moves the brake shoes outward and when i release the e-brake it doesnt return the adjuster to its original position.
    so basicaly every time i use my e-brake it adjusts my brake shoes outward. it doesnt look like any parts are broken or missing. Am i missing something, is this suppose to happen or has anyone else had this issue?
  2. Jan 8, 2018 at 7:11 AM
    Clearwater Bill
    Billy
    Largo Florida
  3. Jan 8, 2018 at 7:18 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Using the e-brake on a regular basis is how your rear brake shoes stay in proper adjustment. When you pull the e-brake, the cable pulls on the bellcrank which pulls on another short cable attached to the parking brake lever. The parking brake lever has an automatic adjusting plate attached to it that rests against the adjuster wheel. When you pull the parking brake, if the adjusting plate can move one or more teeth it will tighten the brakes a little. Once the shoes are properly adjusted, using the parking brake won't move the adjusting wheel anymore until the brake shoes wear down enough to allow another click of the adjuster wheel. Hope that makes sense.
    Here's a video about replacing the rear brakes that gives more information if you're interested.
    https://www.youtube.com/embed/IJkVEBYSecs
    newtotacos00[OP], Xbeaus and jammer like this.
  4. Jan 8, 2018 at 8:52 AM
    Glamisman
    Glamisman Well-Known Member
    I must have taken mine apart 3 times looking to see what the issue was. Everything "looked" good and I was stubborn about not listening to what other peeps said about replacing the springs and adjusters. The dealer had to order erverything and it was the down time that turned me off of going the dealer route for parts in the first place. New factory shoes, springs and adjusters and no problem since.
  5. Jan 8, 2018 at 9:00 AM
    Indy
    Indy Master of all I survey.
    Kind of. Many Drums self adjust when you brake in reverse, you don't have to ever use a parking brake. There are a handful of different drum brake methods out there, not 100% sure which toyota uses.
  6. Jan 8, 2018 at 9:08 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Not 1st gen Taco drums, Timmah is correct.
    In fact there is no need to do an "initial" adjustment of new shoes by turning the star wheel via the slot in the backing plate. Simply toggling the e-brake lever back and forth does the job, in seconds. Unless over travel of the mechanism is happening, due to wear/sticking/adjustment.
  7. Jan 8, 2018 at 9:09 AM
    Taco Hell
    Taco Hell Well-Known Member
    Lititz, Pa
    2007 TRD Sport DC Prerunner
    Agreed!
  8. Jan 8, 2018 at 9:11 AM
    Indy
    Well, there ya go :) free up the adjuster and life should be good.
  9. Jan 8, 2018 at 9:18 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    "Free up" then adjust the bolt that limits the travel of the bellcrank so it does not keep tightening.
  10. Jan 8, 2018 at 9:27 AM
    Indy
    Thinking about my last taco (01), there has to be another method of action tHan juts the ebrake. The parking brakes were rusted solid in the no brake position when I got it and the brakes were adjusted fine. I spent hours beating them into submission so I would have a working e-brake for winching duties.
    And really over my entire life of driving I've seen a p brake used a handful of times. There can't be 99.99999999% of toyota trucks out there with no rear brakes. Although it might explain all the wrecks here in Florida....
  11. Jan 8, 2018 at 11:06 AM
    newtotacos00
    kenny
    2001 toyota tacoma
    thanks for all the input everybody, ill try a few things that were suggested and leave an update. (Clearwater Bill) im not sure how many mile are on the hardware, the truck has 185,000 miles on it and i got it with about 165,000. but some of the springs still have paint and a shine to them so im guessing there not too old.
  12. Jan 8, 2018 at 12:31 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Second opinion and a good read on the subject.
  13. Dec 25, 2020 at 5:14 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Thread is about 1st gen brakes.
    Are you speaking of 3rd gen brakes?
  14. Dec 25, 2020 at 8:43 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Oops...thanks.:santa:
