E-brake cable rubbing on leaf packs with 3" lift
Discussion in 'Suspension' started by MoonCrawler, Apr 28, 2014.
  1. Apr 28, 2014 at 6:22 PM
    MoonCrawler
    MoonCrawler [OP] Well-Known Member
    Sacramento, CA
    2003 Tacoma V6 4x4 TRD
    I've seen that some people have had this problem, but I'm not clear on the best fix.
    I just installed Dakar leaf packs, as well as an AAL, and 3/8" axle relocation plates. I'm somewhere between 3 and 3.5" of lift. I like how things are sitting.
    But my e-brake cable runs OVER the springs, and now that the leaf packs are much thicker, the cable is contacting and rubbing on the edge of the packs before reaching the arm of the drum brakes.
    Thats a problem. But what is the fix?
    Is there an aftermarket kit to correct this?
    Or am I looking at fabbing things?
    Should I extend the arms on the drum brakes (to which the cable attaches) so that the cable goes over the springs higher and more level?
    If so, will the increased leverage be a problem?
    Or should I be considering relocating the entire assembly to somehow go UNDER the springs (the way it should have been done by toyota)?
    If any of you have dealt with and corrected this, could you take pics of your work and post them?
  2. Apr 29, 2014 at 10:02 AM
    MoonCrawler
    Sacramento, CA
    hmmm....67 views and no love. should I have just posted this in the 1st gen. section?
    I know I'm not the only one with my spring set-up.
  3. Apr 29, 2014 at 10:20 AM
    mkatts
    mkatts Well-Known Member
    Joe
    Columbus, OH
    95 Reg cab 4x4 2.7L
    I asked this same question in the 1st gen forum.
    Here is the reply that I got...
  4. Apr 29, 2014 at 11:37 AM
    MoonCrawler
    Sacramento, CA
    Thanks a ton. That's the exact info I was looking for.
  5. Apr 29, 2014 at 3:47 PM
    mkatts
    Joe
    Columbus, OH
    95 Reg cab 4x4 2.7L
    No problem
  6. May 3, 2014 at 4:47 PM
    MoonCrawler
    Sacramento, CA
    Did you have the extenders made or did you fab them yourself?
  7. May 4, 2014 at 5:50 AM
    mkatts
    Joe
    Columbus, OH
    95 Reg cab 4x4 2.7L
    I have not had to do it yet myself. For me was a more so a forward thinking question generated by another post here that had the actual problem.
    Let me find my post and you can asked the guy that provided me with that link.
  8. May 4, 2014 at 6:03 AM
    mkatts
    Joe
    Columbus, OH
    95 Reg cab 4x4 2.7L
    My phone is not wanting to copy and paste the link.
    Do a search on links started by me and look for the post about the cable rubbing should be close to the top.
