E brake cable with lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Modding again, Oct 20, 2021.
  1. Oct 20, 2021 at 11:41 AM
    Modding again
    Modding again [OP] Active Member
    How did you secure the e brake cable once you lifted the truck. Obviously it won’t bolt back to the leaf spring so are you just tie wrapping or did you make a bracket that would bolt to the spring and then secure the cable to that.
  2. Oct 20, 2021 at 11:46 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I used zip ties for the time being.
  3. Oct 20, 2021 at 11:55 AM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    These: tacomaworld.com/threads/universal-emergency-brake-line-brackets-icon-deaver-old-man-emu.716616/
    Looks like he's done making them but it'd be pretty easy to piece it together. Before that I had just cut off the bracket and wrapped some wire loom around them to protect them from abrasion.
