E-Brake Dash Light Staying On w/ebrake disengaged?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95Yota4x4, Dec 16, 2011.
  1. Dec 16, 2011 at 9:42 PM
    95Yota4x4
    95Yota4x4 [OP] -FURY FROM THE SKY
    J.D.
    Houston, Tx
    Black 95 Tacoma, reg cab, 2.7L 4 cyl, 4x4
    4" lift
    couple weeks back ebrake light on dash started flickering on & off while i was driving eventhough i released the ebrake. Checked to make sure it was released all the way. gradually problem got worse & now the light is just always on. is there a contact swith that needs replacement or what is the deal? is there a problem with my brakes, wiring or what? don't see any other symptoms. no squeeling brakes, no burning brake smell, ebrake still does it's job when parked. what's up?!:confused:
  2. Dec 16, 2011 at 9:48 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    top off the brake fluid reservoir in the back drivers side section of the engine bay. MAKE SURE YOU CHECK THE FLUID TYPE ON THE CAP. i went to buy some brake fluid to fill mine and the guy there said oh ya, get dot 4, its basic brake fluid, so i did. well i opened it and went to pour it in and noticed on the cap and it said dot 3...and once opened brake fluid is opened it gets moisture in it and you cant save it. so make sure to check the top of the cap so you get the right stuff.
  3. Dec 16, 2011 at 10:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    As the front brakes start to wear a little, the calipers require more and more fluid to engage the brakes. Toyota's built in warning of brake wear is a sensor that gets activated as the fluid level drops in the master cylinder reservoir to expose the sensor. Typically, you notice it first in mild sloshing around like cornering or braking.
  4. Dec 16, 2011 at 10:34 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    You can mix DOT3 and DOT4 together, just not 5.
  5. Dec 16, 2011 at 10:45 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Good Lord,
    DON'T just go adding brake fluid. It is low for a reason. Find out why. Especially if it was flickering, now it's on all the time.
    Reasons?
    -Leak
    I.E - Busted brake line, wheel cylinder leaking inside the drum. Leaking into the brake booster.
    -Worn Brakes.
    I.E - Less brake pad = caliper retains more brake fluid.
  6. Dec 17, 2011 at 7:26 AM
    Lakelander
    Lakelander New Member
    You might need to adjust the e-brake cable. I had the same thing with my 02 DC. All I had to do was adjust some of the slack from the e-brake cable, it's straight forward just a threaded rod & a locking nut. The e-brake worked fine, but it needs to make contact with a switch that also turned on my DRLs. Hope this helps!
  7. Dec 17, 2011 at 9:28 AM
    95Yota4x4
    J.D.
    Houston, Tx
    4" lift
    Prolly worn drums & shoes. Haven't changed them since I bought it about 2 years ago. Will try that first & get back to you fellas. Thanx.
  8. Dec 17, 2011 at 9:33 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Good advice. But probably don't need to be nervous about it. As noted, normal wear of the pads will produce a lower level in the reservoir. Depending on how far it was filled when the pads were new, it may be that you have 40% left on your pads and need to top the fluid off.
    But it would be best to error on the side of caution and inspect the brakes. Pay close attention to the rear brake wheel cylinders. Those always seem to leak first.
  9. Dec 17, 2011 at 9:35 AM
    joes06tacoma
    Joe
    Central Coast, CA
    X2
    Dot 4 I believe has a higher boiling point but is totally compatible.
    Dot 5 is a totally different product and will ruin the whole system.
  10. Dec 17, 2011 at 7:51 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    Don't top off the fluid, just do the brakes. Mine warning light started coming on a couple months back and I finally had time to do the brakes two weeks ago. Problem solved.
  11. Dec 17, 2011 at 8:34 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    what if the fluid...is actually low?:eek:
    i had the light come on the same way as his, every now and then at first, then eventually it was on constantly. My brakes were done 7,000 miles before that, and all my driving on the 99 was just commuting, so it was very easy break wear. The brake fluid level was right at the top of the low fill line, so i filled it and what do you know, problem solved, light gone.
    also my bad about the dot 3/dot 4. didnt know they were the same, just going off what the filler cap said.
  12. Dec 21, 2011 at 1:31 PM
    95Yota4x4
    J.D.
    Houston, Tx
    4" lift
    Relax fellas. Fluid not low. Still not sure why light is on.
  13. Dec 21, 2011 at 2:46 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not sure if this is the same on the 2.7L.....
    This is ebrake adjustment procedure for 3.4L pull handle (in dash) ebrake.
    http://www.lieblweb.com/ebrakeadjustment.html
    This might give you some ideas of what to check.
  14. Dec 21, 2011 at 3:07 PM
    dollabill415
    dollabill415 Well-Known Member
    my light on my 96 does the same thing and ive been wondering why also...and my brakes have been done recently my pads r still way strong...??? guess i will stay posted here
  15. Dec 21, 2011 at 4:11 PM
    YotaKid62
    YotaKid62 Dirty mall crawler
    Forrest
    North Dakota
    00 Tacoma TRD Sr5 5 speed
    Grey Wire Locker Mod, 3" coil spacers & custom leaf packs, 2" BL, Skyjacker rear nitro shocks, Monroe front gas shocks; 15" eclipse sub & 1400 watt visonik amp with Kenwood stereo, Billet Petals, Black Aries series Grille guard, ebay baja lights (unsure of brand)
    Did you check the light immediately after you checked the release? The springs may be weak and it just isn't releasing all the way. Also make sure theres no mud anywhere jamming anything up. I'm sure its something simple like that.
  16. Dec 21, 2011 at 9:43 PM
    dauange
    dauange Well-Known Member
    Central Ohio
    '01 PreRunner, Dbl Cab, 4 cyl
    My 01 had an issue where the light would stay on after releasing the parking break but if you pushed the handle in the light would go off. Once you stopped pushing it would come back on. There is a pivot point in the parking break cable that is roughly under the driver's seat. It was rusty and I hit it with a little WD40 and worked it back and forth. It had been a periodic issue for a couple of years. Its been 3 years now with no issues. Good luck.
  17. Dec 21, 2011 at 10:08 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    or just unplug the connector at the master cylinder. If the fluid level is correct and the light goes out when you unplug the connection then you have a bad sensor. Seen this a few times at the shop I work at. Most cars have two switches that turns the light on. One for the fluid level and one for the parking brake. That's been my experience anyhow.
  18. Dec 22, 2011 at 8:42 AM
    95Yota4x4
    J.D.
    Houston, Tx
    4" lift
    I'll try that & see what happens. Thanx.
  19. Dec 30, 2011 at 12:46 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    My 1999 has the same issue, but only upon cold startups. I Just unplugged the wire at the master and at the e brake itself, I hit it with some dielectric grease and then sprayed some lithium grease to all the moving parts under the truck. I also pulled the rubber plugs at the rear wheels to inspect the brake shoes and at 130000 miles they are good to go, I did the front pads at around 90000 I think. The brake fluid is "JUST" below full so I'll see if the grease helps in any way. Keep looking back to see what is up. Thanks. Kevin
  20. Dec 30, 2011 at 2:13 PM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    Same issue on my 03. Seems 2 years in a row only in winter when it starts to get cold. Last winter i adjusted the e brake lever at the pivot point under the drivers side door. This seemed to help, I can't remember exactly but the lever is supposed to "click" something like 10-14 times when pulling to fully engage. Mine was a bit over that so seemed like the proble. Adjusted,and fixed. (this was after checking tje physical brakes).
    This winter, started coming on right when it got cold again, sometimes would go off when running at normal operating temperature for an extended peroid of time, but then would come back on when it was sitting for a while. Checked fluid, and was just at min line. No leaks to speak of..... Topped off and lights went out.
