E brake dragging
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Alexbar10, May 1, 2021.
  1. May 1, 2021 at 8:01 PM
    Alexbar10
    Alexbar10 [OP] Well-Known Member
    Alex
    2020 black tacoma TRD PRO MT
    I have a 2020 tacoma and today my e brake started dragging, I can feel it while I'm driving that it isn't disengaging. I also once had one wheel lock up before when off roading. Had to lock the diff to break it loose. Anyone else have this issue and know how to fix it? My e brake is still dragging and I'm worried it's going to cause a lot of wear or catch on fire worst case
  2. May 1, 2021 at 8:16 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Lifted truck or stock?
    tcjacado likes this.
  3. May 1, 2021 at 8:18 PM
    tcjacado
    tcjacado Well-Known Member
    Most likely your e brake cable is stretched.
    Its attached to the the leaf pack on the driverside, via a bracket.
    Tacospike likes this.
  4. May 2, 2021 at 7:20 AM
    Alexbar10
    Alex
    Stock
  5. May 2, 2021 at 7:27 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  6. May 2, 2021 at 7:43 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The e-brake and the rear brakes in general are finicky. I’ve had my rear brakes seize up multiple times after being exposed to water off road and at the car wash. I haven’t encountered the drag you are describing though.
  7. May 2, 2021 at 7:47 AM
    tcjacado
    Did you was the truck recently and let it sit after?
  8. May 2, 2021 at 7:50 AM
    gudujarlson
    Minnesota
    In one case after the car wash yes, but I drove it a mile before I parked it in the garage. Other times it happened after driving through semi deep muddy water and then applying the e-brake.
    tcjacado[QUOTED] likes this.
  9. May 2, 2021 at 8:06 AM
    Tigris99
    Tigris99 Well-Known Member
    St Louis
    2021 AG Trail edition
    He's not the only one with rear brake issues. I've chased down poor mpg, mild vibration and such to my rear brakes. Can tell when it's happening too. Feels like something is holding the truck back.
    I've used my e-brake a total of 5 times maybe in the 5500k I've put on mine. 2 of which was yesterday. I had the problem yesterday morning before taking kayaks out and using e-brake on boat ramp. Jacked rear end up and had drag in both sides, left more than right.
    It's not in the cable, something is going on in the drum which I'm pulling apart this week. Get a look at mysf first then call the dealership.
  10. May 2, 2021 at 8:11 AM
    Alexbar10
    Alex
    I just my e brake every day because it's a manual. And it only has 17k miles so I don't think it's out of adjustment. The standard is holding on a slight hill at 2 clicks and i check that regularly.i think mud or dirt got in there
  11. May 2, 2021 at 11:41 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    If there is no damage to the cable assemblies it sounds like time to let the dealer figure it out
  12. May 2, 2021 at 1:31 PM
    Alexbar10
    Alex
    It went away with driving for a bit. But still weird that it happened.
  13. May 2, 2021 at 2:29 PM
    splitbolt
    NW Arkansas
    You assume it was adjusted correctly from the factory; maybe, maybe not. Mine weren't...
    It's 5-7 clicks for 45 ft-lbs of pull force.
  14. Jun 25, 2022 at 8:47 PM
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    Just had my rear drums replaced on my 21....apparently the factory doesn't always adjust the cable properly ‍♂️
