E Brake handle not disengaging all the way
Discussion in '1st Gen. Tacomas (1995-2004)' started by pt law, Feb 15, 2011.
  1. Feb 15, 2011 at 4:14 PM
    pt law
    pt law [OP] Well-Known Member
    Concord, NH
    04 xtracab 4x4 TRD
    Hi
    I have a 2004 4x4 and the E Brake handle is not disengaging all the way. I properly disengage the E Brake but the brake light on the dash will remain on because there is a little play once the E brake handle is pushed in. I can push the handle in about a cm (very easy to push with just one finger) and the light will go out. If I hit even the smallest bump in the road, the light will come back on. I push the handle in and it goes out again. I had the same problem on my first Tacoma. (Bought both trucks with this problem).
    Does anyone else have this problem and if so, can I fix it myself and how?
    Thanks in advance!
  2. Feb 15, 2011 at 4:18 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    hey and welcome there are many members that will be able to help you. i cannot on the other hand try the search function it might turn up something but somebody should get helping you soon hopefully
  3. Feb 15, 2011 at 4:18 PM
    johnw
    john
    orlando florida
  4. Feb 15, 2011 at 4:20 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Having this same problem on my 01, any suggestions would be helpful.
  5. Feb 15, 2011 at 7:07 PM
    TacoNinja12
    TacoNinja12 Well-Known Member
    Boone NC
    99 2.7L SR5
    3 inch lift
    mine did that for a while and i checked my brake fluid level, topped it off and fixed it. for whatever reason i dont know.
  6. Feb 15, 2011 at 7:38 PM
    McBride513
    McBride513 Well-Known Member
    Luke
    Cincinnati
    04 4x4 TRD
    Mine was doing the same thing for awhile. We I got it it the air, I found that the parking mechanism on the back of the drum had become siezed from corrosion. I took it off and soaked it in PB Blaster and finanly got it to move freely
  7. Feb 15, 2011 at 11:12 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  8. Feb 16, 2011 at 5:00 AM
    Fati Tacoma
    Fati Tacoma Well-Known Member
    Had the same problem, did what Cmack showed. Worked fine. If that doesnt work tho make sure you check the fluid.
  9. Feb 16, 2011 at 5:03 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    subd. Mine does it in the winter time and not the summer so I'm thinking a lil lube on the spring/cable should fix it.
  10. Feb 16, 2011 at 5:30 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    The problem is a part called a "bell crank". This is the part at the end of the e-brake cable going into the back of the hub. There is a rubber boot that is suppose to protect it but it holds mud and salt which makes the parts not rotate properly from corrosion. My 86 Toy truck and 95 Tacoma both had this problem. The best fix for this problem is to replace the part.
  11. Feb 16, 2011 at 6:23 AM
    Matic
    Rich
    Greenville,sc
    Ok. Just did mine. Getting 12-18 clicks so it was within tolerance. Found the spring under the drivers door and hosed it down with pb blaster.
    pulled the e brake a few times to work it in and VOILA!!! Works perfect!!!!
    Thx cmack. Rep for you.
  12. Feb 16, 2011 at 3:29 PM
    pt law
    Concord, NH
    04 xtracab 4x4 TRD
    Just did mine tonight. Some lubrication to the spring and worked the spring by hand for a little and now the handle fully disengages without any problem.
    Thanks cmack. Great post. Just like Matic said, rep for you also.
  13. Feb 16, 2011 at 3:48 PM
    forestgreen99
    forestgreen99 Member
    as east as you can get in North America
    1999 taco v6 4x4
    OME nitrocharger sports, 882s, Dakar leafs, ARB bumper
    Nice, im doing this in the morning. Mine has been acting up this winter.
  14. Feb 17, 2011 at 6:22 PM
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
  15. Mar 6, 2011 at 2:09 PM
    pt law
    Concord, NH
    04 xtracab 4x4 TRD
    CMack or anyone else out there. Do you know how to adjust the e brake cable so that it tightens the handle? I am getting like 20 clicks when I pull the handle and thought I was supposed to be getting 12-18 clicks when I engage it. If anyone can tell me how to adjust this, would be appreciated. thanks
