E brake handle spins, shaft doesnt
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97tactoy, Dec 6, 2017.
  1. Dec 6, 2017 at 10:05 PM
    97tactoy
    97tactoy [OP] New Member
    Terry
    97 Tacoma 45K
    None
    my button in the e-brake handle has no tension on it when I press it. The handle SPINS 360 degrees, but won't turn the shaft. Seems like it should only spin about 90 degrees.? If I pull back slightly on the handle I can then grab the shaft with my other hand & spin the shaft 90 degrees in a clockwise direction to release the e-brake. Any suggestions will be evaluated and appreciated....... Cheers
  2. Dec 7, 2017 at 6:14 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Afaik the handle is mean to spin freely until you engage the parking brake. As long as it works when you pull the shaft to engage the brake and it works when you disengage the brake when the shaft is pulled out its normal. There was a lot of shaft pulling mentioned right there :spy:
  3. Dec 7, 2017 at 10:42 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    @Dalandser nailed it.
    I usually just turn mine 45 degrees counter clockwise then button and then clockwise to unlock it to disengage the ebrake.
    Dalandser likes this.
  4. Dec 7, 2017 at 12:15 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Why does it look like you're banned?
  5. Dec 7, 2017 at 12:59 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That's totally normal. I'm not entirely sure the button actually does anything.
    The handle will just spin and do nothing as long as you don't pull on it and depress the button (safety feature).
    All I do is pull the handle slightly rearwards (simultaneously depressing the button on back on handle), then twist it a few degrees clockwise, then let go to release the brake. Pull straight on it to set the brake.
    Easy Peasy.
