e-brake help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by speed, Mar 16, 2010.
  1. Mar 16, 2010 at 5:55 PM
    speed
    speed [OP] Member
    i need to order some parts for my ebrake. i need the parts that the cables go to on each back wheel (its like a lever) both of mine are seized and have no idea what they are called to order new ones...
    anyone?
  2. Mar 16, 2010 at 6:14 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Did you try removing them and try to free them. I had the same problem and as rusty as they get, they can be freed up. Mine did anyway.
  3. Mar 16, 2010 at 7:55 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    Just ask the parts department when you go in.
    That's what they are there for.
  4. Mar 17, 2010 at 12:53 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I'm not sure what the actual lever is called, but the assembly is the "bell crank", which would be the lever plus the aluminum bracket that holds it on.
    It is really quite easy to repair yourself if you're so inclined. A detailed guide can be found here http://www.tundrasolutions.com/foru...-toyota-truck-park-brake-bellcrank-repair.pdf
    The basics of it is unscrew a few bolts, clean it up good (and paint), add some grease, and reassemble. Also a good time to change your rear brakes if needed (specially if it was seized while engaged).
    When I recently did mine, I ended up having to hit it a few times in order to get the lever out, but it'll come out eventually.
    I know the dealer wanted to charge me $350-400 to replace both bell cranks.
  5. Mar 17, 2010 at 5:42 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    One of mine seized, so I took it off when I replaced the rear brakes and cleaned it in a parts cleaner and lubed it. It worked great, then the other one seized up a couple months later, and I gave up on my ebrake.
    You don't actually need it anyways, especially in an automatic. In a manual, if it rolls a little on a steep hill, or you're afraid it will, then put it in L4 and it won't budge.
  6. Mar 17, 2010 at 11:34 AM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    I agree, but my state requires a working parking brake to pass inspection...
  7. Mar 17, 2010 at 11:56 AM
    STLharry
    Harry
    VT
    So does mine, yet I've passed 2 inspections without one...
    :D;)
  8. Mar 17, 2010 at 5:41 PM
    04YodaTaco
    04YodaTaco Well-Known Member
    central NY
    04' Tacoma 4x4 base
    New frame mod. 265/75/16 Duratracs.
    $350-400? holy hell! I have a platinum warranty so mine were done for free. They even replaced the rod and spring where the handle is. Probably overkill with that.
    On the paper work they gave me after the repair no mention of lever just bell cranks like Manlaan says.
