e-brake light on
Discussion in '1st Gen. Tacomas (1995-2004)' started by darrinhutch, Jan 27, 2015.
  1. Jan 28, 2015 at 9:48 AM
    darrinhutch
    darrinhutch [OP] Well-Known Member
    darrin
    VA
    83 toyota pickup
    Lift with springs, BFG KM2, yeasu ham radio, custom flat bed, browning shift knob, tools box, mag lite, seat and steering wheel cover
    i use my ebrake prob twice i week. its not that it doesnt get used. i just dont use in on a every day base
  2. Jan 28, 2015 at 10:03 AM
    darrinhutch
    darrin
    VA
    83 toyota pickup
    another question. i have to go to work at 3. if i cant get it fixed in time will it hurt to drive it like it is? or should i take another vechile?
  3. Jan 28, 2015 at 10:23 AM
    darrinhutch
    darrin
    VA
    83 toyota pickup
    any more idea? really wanna get this fixed. i have checked the brake fluid, checked sensor, and checked for leaks.
  4. Jan 28, 2015 at 11:54 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I would think you will be ok to drive it.
  5. Jan 28, 2015 at 12:03 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If the battery light comes on with the brake light then it's a charging issue. Did you try tinkering with the brake master cap to see if that was the culprit. Maybe it's sending a false signal??? Other than that it may just be a short from either sensor to the dummy light.
  6. Jan 28, 2015 at 4:07 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you click on the line below and try that procedure?
    The cable often get stretched and the tension needs to be adjusted.
    If you click on the link below, it'll show you how to adjust it.
  7. Jan 28, 2015 at 6:57 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    This right here. My light was on too, and looking at the fluid you could barely justify adding more because it was just a hair off full. Well, that one little bit was enough to trigger the light. They are sensitive little buggers about having the brake fluid topped off all the time!
  8. Jan 28, 2015 at 7:03 PM
    darrinhutch
    darrin
    VA
    83 toyota pickup
    i WASHED my truck off today before work. just rinsed with water! went to get in the truck and the light was off!! thanks for all the suggestions and help. i guess salt and dirt got around it and messed it up enough for the light to stay on
  9. Jan 28, 2015 at 7:51 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    LOL, typical toyota problem. Some light goes on and you don't even do anything out of the ordinary and then it goes back to normal.
  10. Jan 28, 2015 at 7:59 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    don't believe it, the switch is inside your dashboard or inside your brake fluid jar, I don't think washing it reached either one of these but if its brake fluid then parking the truck at a different angle will make it go off, for a while. if the switch in the dash was stuck then maybe it finally went off or the brake handle was finally moved in all the way but just to be safe you need to check brake fluid level.
  11. Jan 29, 2015 at 9:12 AM
    darrinhutch
    darrin
    VA
    83 toyota pickup
    i have checked my brake fuild. TWICE just to resure my self and its full.
  12. Jan 29, 2015 at 9:12 AM
    darrinhutch
    darrin
    VA
    83 toyota pickup
    i think my truck wanted to get me worried and flusterd for no reason lol
