E-brake light stays on
Discussion in '1st Gen. Tacomas (1995-2004)' started by cole47, Jul 13, 2010.
  1. Jul 13, 2010 at 10:25 AM
    cole47
    cole47 [OP] Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    the "brake" light on my dash wont go off.... how do i go about fixing this? and yes the brake is off :p
  2. Jul 13, 2010 at 10:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    Top off your brake fluid level.
    Green1GT likes this.
  3. Jul 13, 2010 at 10:29 AM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    i didnt want to sound dumb...but could this be caused by my actual brakes going bad? cause i think they are about gone...there squealing pretty bad
  4. Jul 13, 2010 at 10:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    No, but that is an indication of two things: 1) the front pads are shot 2) the front pads are dirty (brake dust accumulation).
    The Brake light in question is hooked to your emergency cable and (some models/years) the fluid reservior. The pitman and clevis in the rear drum may also be seized. I had that happen to my 98.
  5. Jul 13, 2010 at 10:59 AM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    thanks for all your help...i just topped off my brake fluid, it was very low...i also think my front pads are shot simply because ive shot brake clean on them numerous times and i still got nothing, the thing thats getting me is i replaiced my pads last year so i wouldnt think it would be time for new ones but what do i know
  6. Jul 13, 2010 at 11:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    They make a product called disc quiet. It's a blue paste which you can get at Wallyworld or your local parts store. It will stop the squeaking should you pads actually be good. It goes on the BACK of the pad, the part that faces the piston. Just smear some on like you are buttering toast.
    Remember, cheap pads will cause a lot of dust and wear faster then a good quality set.
  7. Jul 13, 2010 at 11:33 AM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    thanks man
  8. Jul 13, 2010 at 11:34 AM
    98tacoma27
    Ben
    Not Beech Creek
  9. Jul 13, 2010 at 12:00 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yeah it can.
    Did the brake light go out yet?
    The brake light can also be caused by the ebrake also. Have you used the ebrake lately? Do you have a pull-handle ebrake lever? If yes....Try cycling the ebrake a few times, see how it 'feels'. Count the amount of clicks you get before it is pulled out entirely. You should get between 12-18 clicks.
    If the ebrake lever seems loose, has more than 18 clicks, and doesn't want to go back in (in a sense) - check your rear brake drums. Check the shoes for wear and make sure they're wearing evenly. Make sure the ebrake cable is not hanging up somewhere and verify the ebrake it completely releasing.
    If you've discovered the ebrake cable has a lot of slack in it (after checking everything), there is a method to get the cable back into spec (12-18 clicks)
  10. Jul 13, 2010 at 4:48 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    Yeah the light is out...it was because the fluid was low
  11. Jul 13, 2010 at 5:04 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    gotta love the easy fixes
  12. Jan 8, 2016 at 11:09 AM
    dirtychemist
    dirtychemist Active Member
    Yes this is 5.5 years old and I'm bumping it. I just had the exact same thing happen with my truck and when I checked the brake fluid it was on the MIN line. Topped it off and it hasn't come back in a few days. It's always the simple things that get you in the end.
  13. Jan 8, 2016 at 11:24 AM
    mmgcny
    mmgcny Well-Known Member
    Long Island, New York
    1995 Taco
    None
    Mine stays on unless it push and turn the hand brake lever a bit. I found that the tension on it can be adjusted to get it to go off. Each time I adjust it, the tension gets sloppy again and it keeps happening. Not really an issue since the brake is not on, the sensor under the dash just thinks it is.
    TashcomerTexas likes this.
  14. Jan 8, 2016 at 11:28 AM
    dirtychemist
    I haven't adjusted mine yet however it's a full 22 clicks to the farthest point and I've considered adjusting it but I never use it and I'll probably adjust it right before I sell it, or Sunday if I'm bored. It's interesting that you say your light comes on AFTER adjusting it and the play coming back. I'd never heard of that, or the play coming back after adjusting.
  15. Jan 8, 2016 at 11:30 AM
    mmgcny
    1995 Taco
    None
    Its the tension the opposite way - Mine is at like 20-25 clicks to get it on. When I push to off there is a little slack in the last 1/4 inch or so.
  16. Jan 8, 2016 at 1:04 PM
    mmgcny
    1995 Taco
    None
    I found this image online - if this makes contact, the light goes off.
    dirtychemist likes this.
  17. Jan 10, 2016 at 1:20 PM
    pofarm
    pofarm Well-Known Member
    Greg
    SW MO
    1996 Taco
    Mine was on when I bought it. I could push the e brake handle in and it would shut off, but come right back on when I let go of the handle. My problem was rust/corrosion on the bell crank under the cab and both bell cranks on the rear backing plates. I cleaned and lubed everything and now the light stays off. The bell crank under the cab has a return spring on it that is fairly weak. If the bell crank doesn't move freely, the spring can't return it far enough to keep tension on the e brake handle so it won't keep good contact with the switch pictured above.
    bell crank under cab
    bell crank on rear backing plates
    byota likes this.
  18. Jan 10, 2016 at 3:14 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Yup, when I bought my truck it had the same issue and this was the solution.
    If your brake fluid isn't low that would be the next thing I'd look at.
    Tacolover92 likes this.
  19. Jan 11, 2016 at 12:08 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Those springs at the intermediate lever need some lube once in awhile they do tend to hang up.
  20. Jan 11, 2016 at 9:14 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    That's a clean image, Pofarm. Did you take he frame off the body for that? (Seems excessive just to lube the e-brake spring :rolleyes:)
    Seriously though, thanks for motivating me to fix/lube mine. I've had a sticky cable for the past 5 years or so. I just ignore it and use low range as a parking brake on steep hills.
