E brake on e locker swap WTF
Discussion in '1st Gen. Tacomas (1995-2004)' started by SilverlineShockService, Aug 10, 2015.
  1. Aug 10, 2015 at 9:47 PM
    SilverlineShockService [OP] Well-Known Member
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    Ok so i figured out that the ebrake aint the same on this axle because its off a 04... and abs. anyways from what im thinking can i buy the cable for a 04 and the hard ware for it. is the mechanism the same on a 04 from the cab all the way to the driver door where that sping loaded arm is?
  2. Aug 11, 2015 at 12:47 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just what is different about it??
    Can you not just adapt your cable to where the new rear e-brake comes out of the backing plate.
    Why change any more then you need to.
  3. Aug 11, 2015 at 1:24 AM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    The cable is to short the new axle the back plate has the levers on the bottom. Instead of the cable going over the spring it's under now
  4. Aug 11, 2015 at 5:31 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Will it clear if you just extend the cables ?? simple to just make cable extensions
  5. Aug 11, 2015 at 4:20 PM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    idk how to make cable extensions
  6. Aug 11, 2015 at 4:20 PM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    and if i did that doesnt seem like it would be right
  7. Aug 11, 2015 at 5:18 PM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    hoping someone will chime in and give me a answer because my head is spining about it. it might not seem like a bad thing but i always use the e brake because im a manual if i was automatic i wouldnt give a crap.
    just a thought can i spin the back plate so the e brake lever is on top? idk just a idea knowing im not using the abs sensor
  8. Aug 12, 2015 at 12:19 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Take some pictures of the rear.
    If you rotated the backing plate then your wheel cylinders would be on the bottom
    You have used this rear in another vehicle and just swapped it to this one.??
    Having never been under a 2004 I have no idea why they would redesign the rear brakes.
  9. Aug 12, 2015 at 12:23 AM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    What do you mean by the cylinders as in the brake pistons?
    The 04 was a sr5 which was abs my truck isn't so the rear end I have doesn't have the sensors.
    The way the cables are mounted on the rear end are different. I'll see when I can get to my truck and take some pictures my buddy has a 04 and I'm gonna look at it side by side and see what I can do. I know it's possible just trying to figure it out
  10. Aug 12, 2015 at 12:38 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Does this have rear drum brakes ?? Rear disc brakes ??
    As the emergency brakes are quite different
    The ABS sensors are just going to be redundant
  11. Aug 12, 2015 at 1:50 AM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
  12. Aug 12, 2015 at 2:14 PM
    Wulf
    Wulf no brain just damage
    rock raisin
  13. Aug 13, 2015 at 2:42 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I think if you make or buy the correct brackets to hold the rear cable down lower on the rear .
    Your cable should work .
    But without being hands on it is at best a guess
  14. Aug 13, 2015 at 6:54 PM
    Indy
    Indy Master of all I survey.
    Just replace the cables.
  15. Aug 13, 2015 at 6:56 PM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    to 04 cables and the whole cable or just from the cab next to the door to the axle?
  16. Aug 24, 2015 at 9:39 AM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    All you need is the cable from the lever under the cab to the axle. It routes the same along the frame, but goes over the axle to the back of the axle housing. There should be a guide mounted to the back of the diff housing too.
  17. Aug 24, 2015 at 10:09 AM
    98 Taco Max
    98 Taco Max Well-Known Member
    Max
    Calgary, AB
    v6 Tacoma 4x4
    i might do this in the future, can you not just use your original brake parts and swap the backing plates/drum assembly + cables and levers onto the 04 axle? i haven't looked closely at the newer axles (mines a 98) so i dont know
  18. Aug 25, 2015 at 12:17 PM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    the 04 has abs so the axles are different i believe because it has the abs gears at the end of the shafts
  19. Aug 25, 2015 at 12:20 PM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    figured it out talked to the dealership had him print out the break down sheets and the whole cable will be replaced and comes with all the guides and brakes for a little under 100 bucks i think it was 91$ so got it all figured out:)
  20. Aug 25, 2015 at 6:59 PM
    markmb45
    Mark
    Utah
    The ads axles have the tone ring for the sensors. I believe the axle seal sets further back in the housing. You would need to measure the difference between housings. Not sure if the axle seals are different sizes too. Easier to install the 04 cable. Good luck
