e brake stuck?!?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eman5pt0, Aug 7, 2010.
  1. Aug 7, 2010 at 6:55 PM
    Eman5pt0
    Eman5pt0 [OP] Well-Known Member
    E
    NY
    alright so i washed the truck today and pulled it in the street, pulled e brake up than maybe a half hour later i went to run to 711 and took the ebrake off put it in gear and it wouldn't move, i revved it up pretty good to and it didn't budge the tire wasn't even spinning i didn't want to burn the clutch to bad so i stopped. i even tried keeping it out of gear and trying to push it and it seems like something is stopping it from moving, again the ebrake was not on.
    anyone have any ideas what might be causing it ?
    thanks
    _E
  2. Aug 7, 2010 at 7:01 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Sounds like either:
    - E-brake didn't disengage
    - Main drum or caliper is stuck
    - differential is seized.
    Those would be my main contenders.
  3. Aug 7, 2010 at 8:00 PM
    Eman5pt0
    E
    NY
    yeah i hope its not the diff, i was under it with a flash light, im going to take a better look at it tomorrow during the day
  4. Aug 7, 2010 at 8:02 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    You can try jacking up the diff and try to turn each tire by hand. Make sure you chock the front wheels properly of course.
  5. Aug 7, 2010 at 8:40 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I've had the exact same thing happen a couple years back after washing the truck then letting it sit overnight. In the morning it wouldn't budge...finally after giving it some extra gas it broke free. It only happened that one time and I figured the brakes got rusted up or stuck...hasn't happened since. Let us know if you find out anything.
  6. Aug 7, 2010 at 8:44 PM
    myname150
    myname150 Well-Known Member
    Sooo what if tacoma's had Discs' in the back instead of Drums' for brakes? Would that help reduce the chance of a stuck e-brake? :confused:
  7. Aug 7, 2010 at 8:46 PM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    doesnt sound like e-brake. If you gave it quite a bit of gas i think the truck would still move a little. Sounds like something is stuck.
  8. Aug 7, 2010 at 8:49 PM
    OffroadToy
    4X4 Offroad
    Ya got me... I'm not even sure if a stuck e-brake caused the problem.
  9. Aug 7, 2010 at 8:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Probably not. Rear disk brakes often have a drum brake inside them for the parking brake.
  10. Aug 7, 2010 at 9:01 PM
    OffroadToy
    4X4 Offroad
  11. Aug 7, 2010 at 9:07 PM
    Eman5pt0
    E
    NY
    i had it revved at 2 -3000 rpm the first time i reved it up it almost stalled
  12. Aug 7, 2010 at 9:10 PM
    saltwater taco
    saltwater taco Well-Known Member
    Brandon
    Telluride, CO
    2001 3.4 5spd 4x4 TRD
    softopper, sleeping platform
    Mines done that a couple times. I just worked the brake peddle and it broke loose.
  13. Aug 7, 2010 at 9:15 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    had it happen once(not my taco). i crawled under the truck and wiggled/pulled on the ebrake cable the whole length of the truck and it popped loose. Just make sure the ebrake is off and the truck is in gear. Id hate to hear you say you crawled under there and wiggled the cable but the truck wasnt in gear and it ran over you...
  14. Aug 7, 2010 at 10:24 PM
    Eman5pt0
    E
    NY
    ya that would suck lol
  15. Aug 8, 2010 at 4:54 AM
    TheOtherGuy
    TheOtherGuy Well-Known Member
    Cajun Country
    05 Access 4x4
    did you try reverse?
  16. Aug 8, 2010 at 8:27 AM
    Eman5pt0
    E
    NY
    yeah
  17. Aug 8, 2010 at 11:37 AM
    supadave888
    supadave888 Well-Known Member
    morgan city La
    4x4 trd sr5
    this happend to me at the boat ramp.. drums got wet and locked up.. put it in 4 wd and drug it up the ramp then started looking at it.. pulling the e brake in and out then was aggravated and shoved the e brake in hard and it disengauged.. hasnt done it since.. pretty sure its just from getting wet..
  18. Aug 8, 2010 at 3:58 PM
    Eman5pt0
    E
    NY
    alright well i jacked up the rear and the right tire spun freely. it was only the left that had locked up. attempted getting the drum off and found the little adjuster in the back to be jammed up. after a while it loosened and i adjusted it so i could rotate it. still couldn't get the drum off, i read here to take a 8mm bolts and work them in to push the drum off but of coarse i had no 8mm bolts laying around. i threw the tire back on and it drives, i have to really hit the brake to feel anything engage, so im going to take it to toyota tomorrow and have them check it out
  19. Aug 8, 2010 at 7:09 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    At least it's moving now and you know where the problem is. Hopefully the dealer won't rape you too much for it.
  20. Aug 8, 2010 at 7:16 PM
    A Tall Midget
    A Tall Midget Active Member
    Conner
    Denver CO
    00 Prerunner SR5 TRD package
    Blacked out grille, painted emblem, Dechromed,
    I had this happen to mine too, except it was during a rain storm and i drove through a foot and a half puddle in the supermarket parking lot...
    my brakes seemed like they wouldnt work very well, after drying out a bit they worked fine
