E brake
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stubbs95tacoma, May 10, 2012.
  1. May 10, 2012 at 7:12 PM
    Stubbs95tacoma
    Stubbs95tacoma [OP] Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    My e brake light is constantly on even when it's not engaged. Help me out?? It's a 95 Tacoma 5spd
  2. May 10, 2012 at 7:15 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    I would guess loose cable and rust causing an closed switch... light on. When is the last time you had your e-brake adjusted?
    Frank
  3. May 10, 2012 at 7:16 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    I tried adjusting it and it didn't turn it off. It has exactly 18 clicks till its fully engaged
  4. May 10, 2012 at 7:18 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
    Well, hold on. I'm sure someone smarter than me will be along any minute and solve this. Best of luck.
    Frank
  5. May 10, 2012 at 7:24 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Thanks frank!
  6. May 10, 2012 at 7:25 PM
    Gorillazrus
    Gorillazrus To be continued...
    01 Prerunner SR5
    5100 Bilistens set @ 1" in front, Wheelers 5 leaf in rear, Leer Topper, TRD Skid Plate, Dual Band Ham Radio
    How's your brake fluid level? Mine comes on when it gets low.
  7. May 10, 2012 at 7:59 PM
    Madjik_Man
    Colorado Front Range
    This
    Especially if your e-brake handle is going all the way back in when released
  8. May 10, 2012 at 8:05 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    ^Yep. That light is also the one to indicate something's up with the brakes.
