E brake?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DownSouthTaco79, Nov 24, 2019.
  1. Nov 25, 2019 at 7:54 AM
    96carboard
    96carboard Well-Known Member
    My first guess would be that one of the cables is seized due to corrosion. The other one won't be able to pull the full distance because of the way the two cables are attached together in the cab.
  2. Nov 25, 2019 at 9:23 AM
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    I have to this to my.
    With drums on (fully seated on hub) adjust star wheel till there friction when you spin the hub and then back star wheel few clicks Til you feel there no friction when you spin the hub.
    Marc70 likes this.
  3. Nov 25, 2019 at 9:52 AM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    You shouldn't be able to lock up the rear tires while the vehicle is moving with the parking brake even if everything is correct. Tacoma rear drum brakes are self adjusting and can be adjusted by driving in reverse at speed and slamming on the brake pedal instead of f_____g with the star wheel adjuster, almost all drum brakes since the 1960's can be adjusted that way, repeat the process several times with new brake shoes. Drum brakes do not have a secondary shoe for the parking brake, only disc brakes have that. The parking brake should keep the vehicle parked on a incline. With brake shoes and drums within spec - if the parking brake doesn't hold the vehicle parked the parking brake cable is probably stretched. Attempting to stop the vehicle with the parking brake will stretch the parking brake cable. The parking brake cable is adjusted under the center console as previously shown in this thread. I hate f_____g with those brake adjusting star wheels, lol, it's far easier for me to sit on my ass and drive in reverse and slam on the brake pedal.
    Marc70 likes this.
  4. Nov 25, 2019 at 10:04 AM
    DownSouthTaco79
    DownSouthTaco79 [OP] Active Member
    Hurley, MS
    2013 DCLB TRD Sport Super White
    I adjusted everything correctly. I wasn't moving but about 3 mph in my yard when trying to use the parking brake. Just wouldn't do much. I checked under the console when operating it and there seems to be a fair amount of slack there. Going to try adjusting it when I get off work. Rear brakes work fine with the pedal so it has to be this. I need this for when launching my boat. I dont want to be in one of those sunken truck YouTube videos!
    LAMCKMA007 likes this.
  5. Nov 25, 2019 at 10:23 AM
    LAMCKMA007
    San Diego county
    2006 DCLB 2WD
    When I'm adjusting a parking brake cable I prefer to do it on a hill and adjusting it until it works (adjust the cable and put it in neutral to see if it holds the parked spot). Overadjusting the cable will stretch the cable and will not make the parking brake work "better".
  6. Nov 25, 2019 at 10:43 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    It is, I just went through this.
  7. Dec 19, 2019 at 7:11 AM
    DownSouthTaco79
    Hurley, MS
    Just an update. This worked itself out with no further input from me.... I can only assume there was some type of "seating" that happened with the shoes? Dunno, works fine now. Thanks for everyone's input and suggestions!
  8. Dec 19, 2019 at 7:17 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Go Team!
  9. Dec 19, 2019 at 7:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
