E-locker 3rd member opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 86scirocco16v, Apr 2, 2018.
  1. Apr 2, 2018 at 8:09 PM
    86scirocco16v
    86scirocco16v [OP] Mack of all trades
    Leavenworth, Washington
    '05 4.0 6sp overland
    Black this black that , 315-75r16 pro-comp A/T's , 285-75-r-16 treadwright gaurd dogs full OME lift with Dakar leaf spring pack, boss airbags, 4.88 nitro gears, dakota digital speedometer calibrator, tjm air locker, arb onboard air, spider tracks 1.25" wheel spacer, sport headlights, brute force fab hybrid front bumper, 6000k 4" led fog lights, 24" double row led reverse light, storm trooper shift knob, rebadged badg-less black mesh grill, Kenwood double din stereo, 400w Rockford 12” sub . Anytime fog lights. Oh yeah almost forgot the 2016 FourWheel camper fleet model for extra traction and a place to crash if you do get stuck or broke down. 2x160watt solar, mppt charge controller by blue sky energy. 3 deep cycle batteries 20gallons water, 6gal hot water, 3.5cf 2way fridge/freezer, 6gallon propane... just getting warmed up.
    hey so I wanted to get some opinions and I know everyone here has them so let’s here em. I recently replaced the rear end on my truck and now have a complete e-locker one with a busted ring and pinion laying around. My question is would it be best to 1 sell the whole thing as is, 2 part it out as is, 3 have it repaired and sell it. I was kind of leaning towards #2 personally. Thanks ahead of time.
  2. Apr 2, 2018 at 8:19 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's a tough one. IMO the main reason someone would want an entire rear end is just so they can add an e locker to a non e locker truck. Having a busted ring and pinion will make it a tough sale because to for new gears and install, you're spending about the same as it would cost to just add an ARB locker. Parting it out and selling it would likely be your best bet. Unless you can do the work yourself, then a junkyard ring and pinion would be a cheap fix, and could sell for decent money
  3. Apr 2, 2018 at 8:25 PM
    86scirocco16v
    So I originally was going to rebuild the gears but thought if someone was wanting to gear lower and add a locker it would be perfect or perhaps keep stock ratios but have the locker. And I do have access to everything needed to rebuild it to stock.
  4. Apr 2, 2018 at 9:40 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Sell it for dirt cheap to TW Member!
