E-locker actuator rebuild kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by vtframer, Jun 14, 2019.
  1. Jun 14, 2019 at 7:24 AM
    vtframer
    vtframer [OP] Well-Known Member
    Vermont
    2001 Tacoma SR5 Extended Cab, 4x4 Manual Trans.
    Anyone know where I can get one? Thanks
  2. Jun 14, 2019 at 7:38 AM
    AKsavanaman
    AKsavanaman Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
    Pretty sure they don't, at least I haven't seen them. Have you taken it off and bench tested it? More often then not it's the gear inside the axle that's seized and needs a bit of love and prying to get loose. Pirate4x4 has an article on how to service the actuator... go in and clean it all out, especially the copper brushes that make contact with motor. But as far as actual rebuild kits, I think you're only option is buying new/used
    cruiserguy and SR-71A like this.
  3. Jun 14, 2019 at 1:37 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    ^^ this
    It's not like these things typically see so much use that parts actually wear out to actually need to be rebuilt. Usually just some cleaning and TLC is what you need.
    I guess the exception would be if it's all rusted to shit... But at that point, a "rebuild" probably wouldn't do anything...
