e-locker for 09's
Discussion in 'Technical Chat' started by nelztaco, Sep 22, 2009.
  1. Sep 22, 2009 at 5:57 PM
    nelztaco
    nelztaco [OP] Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    I've searched the threads for an answer to this and I haven't found a definitive answer one way or the other yet. My question is can you add the oem toyota locking rear diff to a 2009 tacoma which wasn't originally equipped with one.
  2. Sep 23, 2009 at 4:48 AM
    sriley727
    sriley727 Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    No, the TRD off road has a different size rear end from the rest of the Yota lineup.
  3. Sep 23, 2009 at 4:57 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    X2...........It has a larger bolt pattern. You would need to swap the rear end (and add a lot of doo-dads). Or you can go the after market route and install an ARB air-locker (requires on board air) or a powertrax.
  4. Sep 23, 2009 at 5:26 AM
    nelztaco
    Neil
    Levittown, PA
    Ok thanks. I guess I was just hoping that the wiring was there then swap rear maybe a driveshaft and add a button on the dash. Especially since my lsd got reduced to a non-mechanical system which the trd-or shares.
  5. Sep 23, 2009 at 5:32 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    That is about all you would need to do (swapping the axle). You would need the harness for the locker also to run it back to the 4x4 ECU.
    The aftermarket approach is simpler, quciker, and possibly cheaper. If you were to go the Powertrax route, it is just a simple remove the third member disassemble and install.
    The ARB air locker would require the installation of an air-compressor and some hose routing.
  6. Sep 23, 2009 at 8:11 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
  7. Sep 23, 2009 at 9:51 PM
    nelztaco
    Neil
    Levittown, PA
    I think we have a winner!
