E locker help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mhawk78, Jan 25, 2025.
  1. Jan 26, 2025 at 7:23 AM
    Mhawk78
    Mhawk78 [OP] Active Member
    Southern Maryland
    2006 radiant red double cab trd
    Found them sorry, so I get 5 volts on the green and black and not zero but 7 milivolts on the pink,I would think that is zero.
  2. Jan 26, 2025 at 7:27 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    So that would be correct.
    With the truck in 4L backprobe M1 (F12 Pin 2 (Light Green)) and M2 (F12 Pin 1 (Blue)) and check across them with your meter while activating the locker switch, you should see 12v for a few seconds.
  3. Jan 26, 2025 at 7:45 AM
    Mhawk78
    Southern Maryland
    Alright I'm getting the momentary 12 volts,can also hear the motor whir for a second when the button is pushed but it's not engaging I guess as I have spun the wheels and the light continues to flash and and tires spin in opposite directions.
  4. Jan 26, 2025 at 7:49 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    What about if the locker is removed from the rear axle does the light go solid when it's engaged?
  5. Jan 26, 2025 at 7:53 AM
    Mhawk78
    Southern Maryland
    If I pull the actuator and manually engage the locker teeth yes the light goes solid
  6. Jan 26, 2025 at 7:58 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    And your sure your getting the fork engaged in the shift collar properly?
  7. Jan 26, 2025 at 8:02 AM
    Mhawk78
    Southern Maryland
    If by that you mean the axle is actually locked I would say yes as I can't turn the wheels after manual locking
  8. Jan 26, 2025 at 8:48 AM
    Mhawk78
    Southern Maryland
    Thanks for your help I did get it figured out the gears were not catching and therefore not engaging the locker. I definitely feel like a dipstick but it works in the garage with the wheels off the ground so should work with the wheels on the ground
    Dm93 likes this.
  9. Jan 26, 2025 at 8:53 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I need to go look how the locker actuator installs exactly, I'm not super well versed on the locker but I'm suspecting it's not being installed properly.
  10. Jan 26, 2025 at 9:24 AM
    Mhawk78
    Southern Maryland
    This was definitely the problem it was not being installed correctly!(I should fire my installer)works now but did hang up in the locked position the first time I locked it and it was on the ground but the second time it unlocked just fine.
  11. Jan 26, 2025 at 10:18 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Glad you got it going, like I said I'm not that well versed on the mechanical side of the locker. I know more about the electronics side and the 4wd system.
  12. Jan 26, 2025 at 10:32 AM
    Mhawk78
    Southern Maryland
    The electronic part is the part I have no clue about so the testing was a HUGE help! Thanks for your expertise.
