E-locker in rain
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ridgerunner, Dec 17, 2010.
  1. Dec 17, 2010 at 6:02 PM
    Ridgerunner
    Ridgerunner [OP] Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I searched-I cant find anything. Any of you with the diff locker use it in the rain? In the 10 years of this truck's life I only activated it one time, just to see what it was like. I personally didn't dig it too much because of the odd sounds the tires made on a turn. Is it bad to use it on wet pavement?
    So my questions are-
    1-is it advisable to use the locker on wet pavement?
    2-is it advisable to run the locker now and then for maintainance of its function?
    3-are there any of you actually using it on wet road and how's it working for you?
    I imagine it would give me added traction no? but I don't want to tear it up either.
  2. Dec 17, 2010 at 6:11 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    dont do it in the rain only if you want to be tokyo drift
  3. Dec 17, 2010 at 6:13 PM
    jandrews
    '09 FourDubDee TRD OR
    What he said. Jesus people! With the 4x4 and traction aid use on the pavements! That's a paddlin!
    http://www.youtube.com/watch?v=hFgR0m-9FmM
  4. Dec 17, 2010 at 6:14 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    1) no.
    2) might not hurt, but mine works fine after not being used AT ALL by my dad (that's 100,000 miles)
    3) probably not, drive slow
    It's great for offroad situations and being stuck and what not, but I don't see much benefit of running a locker for wet conditions or even snowy conditions. Something tells me the tires would just spin out due to the lack of traction already provided by a wet road. Turning both at the same rate would force the rear axle too much. I would imagine most people use theres for mud, crawling, and stucks. I personally have only used mine in the mud. Maybe some other people can share their opinions
  5. Dec 17, 2010 at 6:16 PM
    jandrews
    DO NOT...NOT...use lockers on road in snow. That shit is downright dangerous.
    Edit: Maybe if you're stuck, but as soon as you get moving, locker goes off. And FFS, don't use it in traffic.
  6. Dec 17, 2010 at 6:19 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Thanks for the swift responses. Happy with the advice you gave:) I will just run it on some dirt patch.
  7. Dec 17, 2010 at 6:37 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    ouch...don't let your locker hear what you asked
  8. Dec 17, 2010 at 6:43 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
  9. Dec 30, 2010 at 10:24 PM
    TmecTaco79
    TmecTaco79 Well-Known Member
    Adam
    Escondido,CA
    06 TRD PreRunner 4x2
    Bilstein 5100's, 33" BFG AT, Magnaflow
    Maybe a dumb question, but can you use the rear diff locker in mud or loose dirt at any speed?
  10. Dec 30, 2010 at 10:42 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i used my lock-rite locker in the snow, no problems
  11. Dec 30, 2010 at 10:42 PM
    TmecTaco79
    Adam
    Escondido,CA
    For sure? cause on the door label it says not to go over 5 mph but thats no fun haha
  12. Dec 30, 2010 at 10:50 PM
    TmecTaco79
    Adam
    Escondido,CA
    Nice. I'm gonna have to find a some mud and loose dirt.
  13. Dec 30, 2010 at 10:50 PM
    TmecTaco79
    Adam
    Escondido,CA
    minus that a haha
  14. Dec 30, 2010 at 10:58 PM
    TmecTaco79
    Adam
    Escondido,CA
    True. I usually try to judge how deep the mud is first. if i get stuck i'll have to call someone hahaha. Anyone live in temecula :D
  15. Dec 30, 2010 at 11:02 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Ist't there a sticker on the door about when (and only when) the rear locker should be used? All three of my Tacos had the same sticker ('01, '05, '10)...
    Not to mention the owner's manual.
    It is for Emergency use only to get unstuck or through or up a normally impassable road, without it. 5 mph MAX. and turn it off once past the problem area... Steering may be difficult when locked... Remember, when you turn, the two tires on the axle must rotate at DIFFERENT rates (why there is a differential there). When both tires are LOCKED together.. they can't do this!
  16. Dec 30, 2010 at 11:12 PM
    David K
    Right.. and you shouldn't red line the engine before shifting either... Because you can doesn't mean you should.
    Seriously their lawyers probably made them say 5 MPH... but there is a reason.
  17. Dec 30, 2010 at 11:46 PM
    TmecTaco79
    Adam
    Escondido,CA
    Well i'm only a 4x2. Not sure if that makes a difference.
  18. Dec 30, 2010 at 11:49 PM
    David K
    No difference... 2WD or 4WD, the rear locker only locks the rear!
    Don't you have the warning sticker on the driver's side door, just below the window... or an owner's manual?
    Be careful, and turn it off before you want to make a turn!
  19. Dec 30, 2010 at 11:53 PM
    TmecTaco79
    Adam
    Escondido,CA
    Ya its on the door and owners manual. But they are both worded different. I just dont wanna blow up my diff. if I'm off roading over 10mph.
  20. Dec 31, 2010 at 12:01 AM
    TmecTaco79
    Adam
    Escondido,CA
    True. I know that eaton has a electronic locker so i cant imagine them selling a locker that will blow up on you. Maybe i'll just have to call them up.
