E locker out of a 2010 tacoma
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by christian06, Aug 13, 2019.
  1. Aug 13, 2019 at 6:04 AM
    christian06
    christian06 [OP] Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    I'm selling this rear end, was gonna put it in my truck but the curbs at my local mall are not that big,lol.
    It is complete from drum to drum, I also have a little harness made to show that it works
    300 and its yours
    I live in Tracy Ca. 95376
    Sold sold sold
    Zac of all trades likes this.
  2. Aug 13, 2019 at 6:07 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    This is a good deal! I swapped my rear for a TRD Offroad with a 3rd party switch to engage the locker anytime. Its been great! I still need to sell my stock axle though...
    GLWS
  3. Aug 13, 2019 at 6:08 AM
    silverstatic
    silverstatic Well-Known Member
    Dennis
    Fresno
    08 FJC
    3 inch lift on 35's, CB install
    Pm me. Let’s talk.
  4. Aug 13, 2019 at 6:26 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Interested. PM incoming
  5. Aug 13, 2019 at 6:32 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    What gearing? And where are you located?
  6. Aug 13, 2019 at 8:00 AM
    christian06
    Cali
    I don't remember the hearing but I do remember it's the same as my stock unit
    Tracy ca 95376
  7. Aug 13, 2019 at 8:01 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    You can’t just put this into your sport, base or sr5 unless OP sells the whole axle housing too which idk cuz no pics.
    PICS???
  8. Aug 13, 2019 at 8:16 AM
    christian06
    Cali
    Its complete bolt in ready, I'm at work so no pics till I get home this eve, sorry about that
  9. Aug 13, 2019 at 8:27 AM
    christian06
    Cali
    I would love to but just don't have the time, it's just sitting in my garage and I figured someone else might need it more than me, I just hate seeing it sit there when it could be wheelin somewhere else.
    whatstcp[QUOTED] likes this.
  10. Aug 13, 2019 at 9:12 AM
    TireFire
    Olympic Peninsula
    If it hasn’t been messed with the gear ratio is 3.73:1.00
  11. Aug 13, 2019 at 9:44 AM
    christian06
    Cali
    I don't believe it has ever been opened, I've only took the drums off to make sure all was good, and made a harness to make sure it functions
    TireFire[QUOTED] likes this.
  12. Aug 13, 2019 at 10:03 AM
    TireFire
    Olympic Peninsula
    Be careful with that. If you give it straight 12v you can burn up or jam the motor driving the worm gear
  13. Aug 13, 2019 at 10:16 AM
    christian06
    Cali
    I just did it to make sure it worked before I bought it, I used a DPDT switch with a little light that comes on to show that its engaged.
    I'm fairly certain that it gets 12v from the factory, there are limit switches inside that stop current from flowing once its engaged or disengaged, it does not use power to hold it one way or the other
    SR-71A likes this.
  14. Aug 13, 2019 at 10:33 AM
    TireFire
    Olympic Peninsula
    Yes but the limit switch sends the signal to the locker ECU which you probably didn’t integrate into the harness
  15. Aug 13, 2019 at 12:42 PM
    christian06
    Cali
    No sir I did not, I felt it was an easier swap without having to get the "brain and speed sensor and all that electronic wizardry that the factory puts in the. My truck was not wired for any of that stuff, was just gonna run a DPDT to the dash that way you it's on demand, just dont turn it on over 5mph, lol
  16. Aug 13, 2019 at 12:43 PM
    christian06
    Cali
    Thx
  17. Aug 13, 2019 at 12:44 PM
    christian06
    Cali
    Or PM me
  18. Aug 13, 2019 at 12:44 PM
    christian06
    Cali
    I believe your right thx
  19. Aug 13, 2019 at 12:45 PM
    christian06
    Cali
    So, I forgot to mention that I live in Tracy Ca. 95376
    It's got 40,000 on it
  20. Aug 13, 2019 at 2:06 PM
    TireFire
    Olympic Peninsula
    Yeah that’s probably not a good idea. I’ve done this swap into a 4banger. Better to get the locker ECU and trick that into thinking the truck is always in 4lo. Then you even get to keep the 5mph safety if you want. Point is that the locker motor will burn up if it gets 12V all the time. It’s not an electro magnet. IIRC It should only be powered while the fork is being moved by the worm gear from locked to unlocked and vice versa.
