E-locker problem/ alignment issue?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TashcomerTexas, May 13, 2014.
  1. May 15, 2014 at 10:54 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Interesting.... What were your alignment specs? Could you post a pic of it?
    Did your locker not engage prior to getting an alignment?
    I don't know jack about motor vehicle mechanics my questions are intended to better understand them.
  2. May 15, 2014 at 10:58 AM
    TashcomerTexas
    TashcomerTexas [OP] My truck is a whiner
    2003 TRD DC Supracharged
    Thanks for the feedback man, yeah ever since I lifted and haven't had a decent alignment I never had to toggle with my locker and the "going back and forth" to engage.
  3. May 15, 2014 at 11:07 AM
    GhostDog86
    GhostDog86 Well-Known Member
    Max
    Chimayo/Santa Fe
    DCSB TRD OR
    Remove mudflaps, Plasti dip badges/ lower val/ and grill, Plasti dip wheels, 5% tint all around, Tinted tails and 3rd, 55w driving lights in rear, Blue LED light strip in bed, Blue LEDs in cab/ cup holders...
    Not sure if serious....
    Maybe trolling...
    But as said before... Your front end alignment has absolutely nothing todo with your rear end locker...
  4. May 15, 2014 at 11:10 AM
    TashcomerTexas
    I'm talking about the rear too. Don't you think I realize now the front end has nothing to do with a rear locker?
  5. May 15, 2014 at 11:16 AM
    GhostDog86
    Max
    Chimayo/Santa Fe
    DCSB TRD OR
    You can't get an alignment in the rear as there are no adjustments on a leaf spring suspension...
  6. May 15, 2014 at 11:17 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  7. May 15, 2014 at 11:20 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    This.
  8. May 15, 2014 at 11:20 AM
    TashcomerTexas
    Well then, as posted earlier I got my answer. Told you me is el noob-o
  9. May 15, 2014 at 11:22 AM
    tomtom
    The Desert SW
    2012 FJ
    If a shop is charging you for a rear-end alignment, start asking questions.
  10. May 15, 2014 at 11:26 AM
    GhostDog86
    Max
    Chimayo/Santa Fe
    DCSB TRD OR
    X2
  11. May 15, 2014 at 11:52 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Oh what have I done. I forgot the sarcasm font.
  12. May 15, 2014 at 12:03 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Well... this went nowhere fast. Entertaining though
  13. May 15, 2014 at 12:07 PM
    TashcomerTexas
    LOL what if I just pulled a whole "oh I wish I did more research before I bought a tacoma" guy kind of thing...I LOVE MY DODGE IM GOING BACK TO DODGE
    May fools y'all.
  14. May 15, 2014 at 12:10 PM
    TashcomerTexas
  15. May 15, 2014 at 8:49 PM
    #35
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Okie dokie byebye.
  16. May 17, 2014 at 1:30 AM
    #36
    UssMoGn
    UssMoGn That Vegas dude
    James
    Las Vegas NV
    05&04 Tacoma SR5
    Home Built Front Bumper HID Headlights LED Cab lights 2013 Radio swap MOLLE DC Insert Traffic Cam F&R 6'' Procomp lift Custom Grillie
    I was messing with a E-locker off a 04 Tacoma that I had just bought, It was owned by a chick and never used day in its life. Would never engage, So I pulled it off, Bench tested pulled off the cover to show the guts, used 12v and made the motor work both ways. Put the guys back together, Stopped working. After more head scratching and more taking it apart, I found out that screws that hold the main plate on if screwed in to tight will stop everything from working. I back the off just a bit and left them snug and worked like a champ.
    Tested everything else...
    Tested the electrical
    Tested the switch
    Tested the Rear by lifting and manually engaging
    Anyway that's my recent experience with a E-locker. Anyway OP you might want take it off and clean it and maybe loosen the screws a bit, might not have to turn so much to get it to lock. My 96 4Runner and 04 Tacoma lock after just a few feet in a straight line and have engaged them with no problems while off road on a obstacle.
  17. May 17, 2014 at 2:40 AM
    #37
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    As mentioned maybe a change in diff fluid (never hurts probably needs changing anyway) & make it a habit of engaging it on a routine basis, just so you know it does work..
    Rear end alignment.... hate to inform the doubters but it does exist, try sheering an axlepin sometime, you'll be pulling your axle back into alignment if you want to drive it again... On to the front end alignment, has no bearing on Elocker ?? Think again, if you have ABS & the sensor in spindle gets knocked around (it happens) or cable gets pinched/seperated kiss Elocker goodbye, its not going to engage, in fact if offroading & somehow the banjo bolt on caliper gets a tiny bit loose (just enough to break seal) Elocker will drop out & wont return until correcting, ANY anomalie with brakes or ABS will take out Elocker for operation...
  18. May 17, 2014 at 4:51 AM
    #38
    tomtom
    The Desert SW
    2012 FJ
    I think you're confusing issues here.
    An alignment is not a standard service on a solid rear axle. If you sheared an axle pin, you broke something and it needs repairing. There are no "alignment" settings for the rear axle to play with. No cams to adjust toe, camber and caster. You replace the axle pin, straighten the frame, replace the shackles, do what you have to do to repair things but taking it to an alignment shop will just get them telling you that your thrust angle is off.
    Your second item listed, again, is not standard part of an alignment. It is a malfunction of the braking system, as you pointed out in your last sentence. Having a leaking banjo bolt won't be fixed by getting the front end aligned. If the front end can get so out of alignment it interferes with the braking system, you have more worries than the e-locker not engaging. Hopefully, the tech would see it and bring it your attention.
  19. May 17, 2014 at 5:02 AM
    #39
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Not confusing anything, I think you guys are, true, rear axle alignment isn't a "normal" proceedure but some here are saying there IS no alignment of it & thats incorrect, also its true that a normal, non eventful front alignment won't take out the locker, but as i said if someone gets careless about what they're doing & snags or pinches ABS cable in the course of alignment, the E locker signs off... That said, does the tech have any business fucking around in that area ?, no, but lets face it , sometimes odd ball shit happens , so you can take from this what you will, but I'll take my "far fetched confusing analogy" Over a bunch of guys giving the OP alot of crap for posting his issue as he interprets it...
  20. May 17, 2014 at 6:56 AM
    #40
    tomtom
    The Desert SW
    2012 FJ
    I think the OP's original question was,"would new UCAs and an alignment fix an e-locker engagement problem?"
    I think the answer is a resounding "no" with some responses less polite than others.
