E locker swap write up (easy way!)
Discussion in '1st Gen. Tacomas (1995-2004)' started by SilverlineShockService, Sep 8, 2015.
  1. Sep 8, 2015 at 5:35 PM
    SilverlineShockService [OP] Well-Known Member
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    Whats up guys I successfully swapped over my elocker axle over and thought I would make a write up on it because I couldn't find many write ups on the swap!
    In my opinion first thing I did was take the bed off its 6 bolts and need a couple peoples help to lift it off and its off and you have all the room in the world after that. You can ever pressure wash everything with it off like I did:thumbsup:
    Unbolt everything off your STOCK axle Take the shocks off. Take the main brake line out. unbolt the portioning valve arm. and finally unhook the Ebrake and unhook the cable from the back plates. take the 4 through bolts off the drive shaft connecting to the 3rd member. drop the axle.
    Go ahead and bolt up the New elocker axle everything reversal of what was stated above. just dont worry about the ebrake because it wont fit anymore ill add to that later!
    like dis:D
    Wiring:
    I went to lowes and bought 5 25foot 14awg packs all different colors this was over kill but will help later down the road if i have a problem.
    making the wiring harness is easy this is how I did it. pictures below:p
    So what I did was tie the 5 wires to a spicket.... lol
    stretch it wires out and cut it even. Then grab a drill and put the 5 wires in the chuck of the drill. then spin it. get it tight nut now so tight it breaks... lol
    now wrap both ends with some electrical tape to hold it from unspinning and take it out of the chuck.
    take the harness and tie it to something like a clothes line and wrap it with electrical tape, wiring loom or something. I did electrical tape TOOK FOREVER...:(
    now thats done you can start splicing it to the OEM short harness that plugs into the third member
    like dis:D
    leave the 2 white/black wires alone they are grounds that ground to the chassis.:thumbsup:
    This was mine
    RED to GREEN/RED
    BLUE to BLUE/YELLOW
    GREEN to GREEN
    WHITE to GREEN/BLACK
    YELLOW to GREEN/YELLOW
    BOTH BLACK/WHITE GROUND TO CHASSIS!!!!!
    (The colors on the right are oem from a standard pinion axle)
    Okay now run the wiring harness down the frame I went the route of the brake light wiring harness and went up through the cab right next to the driver door and seat
    Then into the dash.
    run a positive lead from the battery and fuse it.
    okay the switch
    http://www.lowrangeoffroad.com/toyota-e-locker-switches.html
    spend the money its worth every penny!
    here is the switch diagram with oem colors its as easy as that!:bananadance::bananadance::bananadance:elocker_switch_diagram_copy_1_zpsfqekv65_2af76de4b5d1791c25f9f387caf6ec52ba73a995.jpg
    Screenshot_2015-09-08-17-32-54_zpsyhssry_c0f36a30fd00af2736999848ae872c8ad3c25b5c.jpg
    EDIT: forgot about the ebrake replace the ebrake from the cab to the axle prt#46420-35740 comes with all the factory brakets for about 80 bucks. (make sure that your original doesnt fit before you buy it...)
    thank you hope it helps :thumbsup::thumbsup:
    My first write up!:oops::rolleyes::thumbsup::rofl:
    WARNING! Match the gearing of the new rear end to the front diff! VERY IMPORTANT note: if you have the same as the front you are good!
  2. Sep 8, 2015 at 5:40 PM
    Deere9798
    Deere9798 Well-Known Member
    Charles
    Western NY
    2001 Tacoma 4x4
    Very impressive. I plan on doing this eventually.
    Thanks for the write up,
    _Charlie
  3. Sep 8, 2015 at 5:42 PM
    NicNac
    NicNac Well-Known Member
    Southern Dakota Territoy
    11 DCLB TRD Sport
    Nicely done, Good write up. Would this be the same for 2nd Gen.?
  4. Sep 8, 2015 at 5:44 PM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    Thanks you!
  5. Sep 8, 2015 at 5:45 PM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    not sure im sure the wiring is pretty close.
  6. Sep 8, 2015 at 5:48 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    The only thing you didn't mention in the swap was matching the gears with the front diff. If you need regearing, that is probably the hardest and most expensive part.
  7. Sep 8, 2015 at 5:50 PM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    yes! thanks totally forgot
  8. Sep 8, 2015 at 11:24 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Off topic but OP, is that a paranoid switch plate? Were you not able to get it aligned without that gap on the left side?? I ask because I'm bout to install one myself.
  9. Sep 8, 2015 at 11:48 PM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    I didn't have a gap?
  10. Sep 9, 2015 at 12:19 AM
    bry838
    oregon
    Oh I'm sorry, it totally looks like it, there on the lower left. One other question, to pull the hvac face plate, does the a/c button need to be pulled out or does the face plate just pop off and button stays in place? My '00 has a lil different control panel but the a/c button would be same.
  11. Sep 9, 2015 at 12:46 AM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    You gotta get a screw driver and carefully pry it out the a/c button is a plug of its own it's like 2 inches deep into the face plate. Hard to explain
  12. Sep 9, 2015 at 7:37 AM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    That's weird your ebrake wouldn't work, I did this same swap and no issues using my ebrake cable on the new axle.
    I did end up having my non trd backing plates pressed onto the elocker axles though because they were rust free.
    1997tacomav6 likes this.
  13. Sep 9, 2015 at 7:52 AM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    Yeah I have a 97 and they run above the axle the newer 1st Gena run across the pumpkin
  14. Jul 10, 2016 at 9:02 AM
    TBeers
    TBeers Well-Known Member
    Montana
    Tacoma DLX 3.4 4x4
    Great write up, thank you! Just swapped a 410 trd locker in yesterday and need to wire it soon. Killer deal 400$!!! I have the stock wiring from the locker that would tie into the chassis wiring harness. Do you know where the male connector is available?
    Thanks!
  15. Jul 10, 2016 at 9:13 AM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    McMaster-Carr sells almost every type of conductor you might need. Instead of making your own and covering them in electrical tape you can buy 18-7 or 18-5 conductors by the foot. I used 18-7 and added a relay so I could use the factory RR DIFF LOCK switch and dash light.
  16. Jul 10, 2016 at 9:19 AM
    TBeers
    Montana
    Tacoma DLX 3.4 4x4
  17. Jul 10, 2016 at 11:41 AM
    xcmtb83
    Iowa
  18. Aug 11, 2016 at 7:30 PM
    TBeers
    Montana
    Tacoma DLX 3.4 4x4
    Sweet, thank you for your help! got all my supplies, wiring this weekend
  19. Aug 12, 2016 at 10:35 AM
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
  20. Aug 15, 2016 at 9:18 PM
    TBeers
    Montana
    Tacoma DLX 3.4 4x4
    Yea, I grabbed scrap 10 conductor (18 gauge) from the shop I work at. Very cheap ha ha ha
