e locker swap
Discussion in 'Off-Roading & Trails' started by adamw, Dec 3, 2011.
  1. Dec 3, 2011 at 8:44 PM
    adamw
    adamw [OP] Well-Known Member
    sunnyvale, CA
    06 prerunner-> FJC 4x4 swap
    wanting to swap an e locker into my sr5. I know I can mod the housing but it will def be a pita. I have found a lot of older 4runner e locker 3rds and 1st gen rear ends. If I did end up swapping just the 3rds would the 4 runner ones fit?
  2. Dec 3, 2011 at 8:56 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
  3. Dec 3, 2011 at 9:16 PM
    adamw
    sunnyvale, CA
  4. Dec 4, 2011 at 3:22 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Potentially next year. You should be able to. Is it not the same axle?
  5. Dec 5, 2011 at 8:07 AM
    adamw
    sunnyvale, CA
    no sr5 open diff so it'll need some cutting
  6. Dec 5, 2011 at 12:13 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    1gen housing won't fit your truck because 2gen is wider axle. so that NO. e-locker 3rd is the same acroos the years, housing changed (width)
    Not sure what is your cost but I would consider options.
