E-locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Mar 17, 2014.
  1. Mar 17, 2014 at 5:47 PM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Can a 03 elocker axle be transplanted to a 99? The ebrake in the back looks a little different, other them that it looks the same
  2. Mar 17, 2014 at 6:13 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Not unless you get the whole axle drum to drum. The ring gears are different sized between trd and non trd, and the bolt pattern for the 3rd member flange is different between the two. In addition you would need to make sure the great ratio matched your current gear ratio
  3. Mar 17, 2014 at 6:23 PM
    smmarine
    Melbourne FL
    That's what I'm looking at. The whole axle. I know the 8.4 and 8.0 3rds don't match. Was just wondering on the different e brake set up, and I'm sure it has ABS. And it should be the same 4.10 gears. It's coming off a 3.4 manual trd 4x4
  4. Mar 17, 2014 at 6:35 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    E brake doesn't matter. It should still hook up fine. Non abs have the e brake cables going over the leafs, abs all the e brake cables are on the back of the axle
  5. Mar 17, 2014 at 7:25 PM
    smmarine
    Melbourne FL
    His has it then. Shouldn't be a problem to hook up though right?
