E or XL Load Rated Tires on a Midsize?
Discussion in 'Wheels & Tires' started by Mad German, Oct 17, 2024.
  1. Oct 17, 2024 at 6:22 AM
    Mad German
    Mad German [OP] Well-Known Member
    2016 TRD Off Road
    For the guys who have E or XL load rated tires, have you noticed a considerable difference in ride quality? I'm considering the Cooper Rugged Trek, but some folks say they'll knock the fillings out of my teeth; they'll ride like a buckboard wagon; they're like stones. Other say they can't tell a difference at all.
    If you've had both C or SL load rated tires and have also had/have E or XL load rated tires, please tell me what your thoughts are. Are you happy with the E/XLs? Would you buy them again?
    Thanks all!
  2. Oct 17, 2024 at 7:27 AM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    I have a hard time with the mid size term. They’re small trucks. Mid size is more an f150 I think. Strictly my opinion.
    People are putting E rated tires for off roading and sharp rocks. If you don’t go kidding or heavy off roading then the heavier thicker tires are only dead weight. They make some really well built SL tires out there and you don’t need a LT tire on a taco. Just a preference for some off roaders. They are a lot heavier and the ride is harder but not teeth chattering. They’re made for hauling weight so empty they’ll be a rougher ride than a softer sidewall tire. They also will lose traction on wet road opposed to the more pliable SL’s, and as per my comment of heavier, E rated tires are, and will lower your mpg’s
  3. Oct 17, 2024 at 7:44 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I have Rugged Trek XL in 265/70r17 on my 2022. Not much difference from the stock tires. X
    An XL (extra load) passenger rated tire isn't near as stiff as an E rated light truck tire.
    Mad German[OP] likes this.
  4. Oct 17, 2024 at 7:48 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    XLs, in general, are barely stiffer than stock (SL). Ultimately it comes down to the load index. An XL in 116 or so will be stiffer than say an SL in 109 or 110. An XL in 116 and an SL in 116 will basically feel the same, although the XL will have a slightly higher carrying capacity. It also comes down to the size as to how they will feel.
    None of those above are close to the stiffness of an E, though. The letter designations are a totally different category of tire; light truck (LT), and E’s are one of the stiffest of those available. The reason is LTs have more sidewall thickness and E’s are one of the thickest sidewall LTs available. XLs just have slightly thicker sidewalls than SL, and both are much softer and more pliable than an LT sidewall. Even a load C LT.
    Mad German[OP] and atc250r like this.
  5. Oct 17, 2024 at 8:15 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    If you dont nead them all your doing is decreasing mpg, get up and go can decrease. Usally tire life and ride quality degrade. Noise is generally worse with their patterns.
    My recent experiment of lightening up my Siennas 17 rims from O.E. 28lbs to 21lbs gained almost 20% on hyway mpg. Thats a huge total weight lose of 28lbs for all four tires/rims . I know these are 225 60 17 but bigger tires can be worse extreems. Rims are still rated @1700lb rated with the new tires. The new tires are LT/SUV a/s tire of 28lbs each. The tires are a more aggressive pattern for heavy rain & snow. I will be changing them asap though as they start singing at 30-35 mph.
