E rated or not
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adam2180, Sep 7, 2014.
  1. Sep 7, 2014 at 2:08 PM
    adam2180
    adam2180 [OP] Well-Known Member
    Dartmouth NS Canada
    2010 SR5 Double Cab
    Im buying new Michelin LTX M/S2 this week, The E rated tire is only $10 more per tire. would the heavier tire be any better or last longer? I seldom leave the pavement.
  2. Sep 7, 2014 at 2:17 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Will cost you at the pump and in braking distance going with E.
    If you dont leave the pavement you have not worries with C or standard rated tires.
  3. Sep 7, 2014 at 2:22 PM
    adam2180
    Dartmouth NS Canada
    2010 SR5 Double Cab
    The new tire is only 1lb heaver per tire, Im going back to stock size.
  4. Sep 7, 2014 at 2:25 PM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    That is the same tire we run on our 3/4 ton truck. Might be a little overkill. Truck will probably have a rougher ride.
  5. Sep 7, 2014 at 2:43 PM
    adam2180
    Dartmouth NS Canada
    2010 SR5 Double Cab
    I think im going with the p rated tire then, Ill put the $ I save toward beer.
  6. Sep 7, 2014 at 2:55 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    I run E load Firestone MTR. VERY rough ride, but the tire lasts longer for me than a normal C radial. I had Dick Cepek FC II's before the firestones which were a very good ride.
  7. Sep 7, 2014 at 3:50 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    run a P rated or load range C tire on these trucks unless you do serious off roading. Your MPG will be better, and ride will be much better.
  8. Sep 7, 2014 at 4:49 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Go with the P tire. I got mine at Costco, they ordered the E-rated (LT) tire by mistake. I refused to accept them. They got the P tire in a few days later, and they were about $80 less for the set. Two years - great tire, you'll notice the difference the first time you drive when it's wet.
  9. Sep 7, 2014 at 5:38 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    If you actually put stuff in the bed of you truck I'd go with the Load Range C tire, not a P or E. The E will ride rougher/stiffer and these trucks really don't have the load carrying capacity or the braking power to be carrying a load that would need an E rated tire.
