E rated tire high pressure valve stems
Discussion in 'Wheels & Tires' started by hiflo, Jan 17, 2019.
  1. Jan 17, 2019 at 5:48 AM
    hiflo
    hiflo [OP] Member
    just ordered new E rated tires and there was a note to use high pressure valve stems of 80 psi any info about this would be helpful thanks
  2. Jan 17, 2019 at 6:09 AM
    trdt44
    trdt44 Well-Known Member
    Trent
    Utah
    2017 Tacoma TRD OR
    You shouldn't be running the tires at 80PSI, unless these are on a 3/4ton or 1ton truck. You will be okay with regular valve stems assuming your truck does not have TPMS.
    SR-71A likes this.
  3. Jan 17, 2019 at 6:10 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You should run around 35 PSI. If you're up near 80, your truck will ride like fred flinstones car with stone wheels.
    ChadsPride and eccracer104 like this.
  4. Jan 17, 2019 at 6:13 AM
    Clearwater Bill
    Billy
    Largo Florida
    Fake news perpetrated by collusion of embossed-on-the-sidewall max pressure rating and a lawyer who looked at a tire once.
    SR-71A likes this.
  5. Jan 17, 2019 at 6:25 AM
    hiflo
    hiflo [OP] Member
    yea I didn't even think about it i'm sure I will never run 80 psi but the max load rating of the tire is at 80 psi and normal valve stems max rating it at 65 psi high pressure stems max out at 80 psi rating I had to look it up
  6. Jan 17, 2019 at 6:29 AM
    Clearwater Bill
    Billy
    Largo Florida
    https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=196
  7. Jan 17, 2019 at 6:31 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    running E rated ST Maxx 265-75x16LT......
    plain ole rubber stems......$3 a pop.........screw the TPMS stems
  8. Jan 17, 2019 at 8:37 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Since the tires are capable of 80 PSI, I recommend installing the valves that match even if you don't plan to air up that high. They are usually the same price too.
    jackkpecoraa18 likes this.
  9. Jan 18, 2019 at 7:16 AM
    hiflo
    hiflo [OP] Member
    thank you discount tire for the normal intelligent response! I am going to the Toyota dealer for mounting and balancing they have a good price in my area. would they have the high pressure valve stems or should I buy the correct stems and bring them with the tires?
  10. Jan 18, 2019 at 10:28 AM
    Discount Tire
    Arizona, USA
    I imagine they would have them readily available. If not, your local auto parts store should have them too :thumbsup:
  11. Jan 18, 2019 at 2:47 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    On behalf of everyone in this thread, I apologize for our abnormal, unintelligent responses. It won’t happen again. :rolleyes:
    BlueFalconActual and eccracer104 like this.
  12. Jan 22, 2019 at 7:42 AM
    hiflo
    hiflo [OP] Member
    just got back from my local Toyota dealer they had no idea what a high pressure valve stem was. said they would not know what to even order. why would you want to air the tire up that much huummm
  13. Jan 22, 2019 at 7:49 AM
    Discount Tire
    Arizona, USA
    Are you running TPMS sensors in the wheels or standard rubber valve stems?
  14. Jan 22, 2019 at 8:41 AM
    hiflo
    hiflo [OP] Member
    standard rubber valve stems stock 2003 Tacoma aluminum wheel.. the dealer it the only place i could find that road force balanced don't want to use them now seems strange they dont know about the valve stems
  15. Jan 22, 2019 at 8:56 AM
    Discount Tire
    Arizona, USA
    TR600HP is what you need. We have them available at $12.00 for a new set of four(4) - FREE delivery of course.
  16. Jan 23, 2019 at 8:07 AM
    hiflo
    hiflo [OP] Member
    thank you discount tire for the help and info !! found the high pressure valve stems yesterday a shop in my local area that services a lot of off road equipment had them also $3 each. he wanted $120 to change out the tires and balance that seems like a lot for regular balancing.. called another Toyota dealer 40 miles away they wanted $112 for the same thing but with road force balancing. they also had no idea what high pressure valve stems were going to go there but bring my own valve stems this time .. thanks for the help
  17. Jan 23, 2019 at 8:26 AM
    Discount Tire
    Arizona, USA
    It's our pleasure! Glad you found what you were looking for :thumbsup:
  18. Jan 25, 2019 at 4:44 PM
    hiflo
    hiflo [OP] Member
    ok both of these Toyota dealers suck! 2 tires had acceptable road force and used about 3.5 ounces to balance. the other 2 tires had excessive road force and were calling for around 15 ounces of weight they did not know how to fix it so they static balanced the tires which used just under 4 ounces of weight per tire and said it was good. bump bump shacking at some speeds not that bad but not that good they said it might be the tires were on the bottom of the stack and got misshapen I waited about 4 hours the tires sat in the shop for over 2 hours before they got to them I will never go there again !!
  19. Jan 25, 2019 at 4:57 PM
    BlueFalconActual
    BlueFalconActual Some dude
    2017 DCSB TRD OR 4x4 MT
    This may come as a shocker, but that's why most people wouldn't recommend running a 10 ply tire on a Tacoma. Yes, I understand that it can be done, but that doesn't make it ideal because it can cause issues such as problems balancing, decreased fuel mileage etc. On top of that, adding more air into said tire just because that's what the sidewall says it can take under it's max load only exacerbates the problem.
    Tire pressure is dictated by the weight of the load that they are carrying coupled with the volume of the tire. Just because you CAN put 80 psi in your tires, doesn't mean you should especially if those tires hold more air volume (ie are bigger) than stock.
    -Your friendly Tire Industry Association certified dude
  20. Jan 25, 2019 at 4:59 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I've got E rated 265's and tire pressure is set st 26psi !!!!
