E-rated tires on a pro
Discussion in 'Wheels & Tires' started by Jeepnick, Aug 11, 2017.
  1. Aug 11, 2017 at 2:47 PM
    The Boat Oar
    The Boat Oar Well-Known Member
    2014 Blacked Out TRD Off-Road
    What is a good tire in 265/75/16 that still has a decent ride?
  2. Aug 11, 2017 at 2:57 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Does anyone has a clear and simple explanation (or chart) of what the difference between E, P, C,etc tires are??
    The Boat Oar likes this.
  3. Aug 11, 2017 at 3:00 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    I run 265/75/16 KO2 which are E rated and I agree there's a mpg loss but handling firmed up for the on my OR which stock suspension. I had C rate Goodyear Duratrac and they were as soft as stockers.
    I know the Sports would be a rougher ride but the Pros are on the soft side stock, no?
  4. Aug 11, 2017 at 4:41 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    General grabber X3, C-rated. Loving mine!
  5. Aug 11, 2017 at 7:50 PM
    The Boat Oar
  6. Aug 11, 2017 at 8:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Very simple but it gets complicated.
    P, C and E are load ratings. C and E are LT tires that are designed for extra load carrying ability on light trucks, hence the "LT." P is a passenger tire. Usually, C and E have a heavier carcass (extra rubber) that will allow higher pressures which will allow additional load carrying ability. Why people would want to use them on a little truck like the Tacoma is the thicker sidewalls to resist a puncture from sharp rocks or a tree limb. The drawbacks are heavy and stiff which causes your light truck to ride rougher and reduces your MPG due to rotating unsprung mass.
    Where it gets complicated is when you start talking about proper inflation pressures for maximum load carrying ability. The P rated tire actually has a higher load rating at 35 psi than either a C or E rated tire at that same pressure. But, that's close to max pressure for a P rated tire. The C rated tire and the E rated tire can go much higher in pressure and eventually at those high pressures the higher load rating can be achieved. Your Tacoma with maximum load and pulling max tongue weight trailer is still under the P rated load rating so going to a C or E would only be for off road puncture resistance.
    Hope this helps.
  7. Aug 11, 2017 at 9:25 PM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    Whew that's a lot to take in.
    hiPSI[QUOTED] likes this.
  8. Aug 11, 2017 at 9:37 PM
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    If you want an aggressive tire then look at the Dick Cepek Extreme Country. While it is rated as an E tire it technically kind of isn't in that it has a lighter 2-ply (yet high strength) sidewall that doesn't add weight, rolling resistance, or ride harshness. The tire is made by Cooper and is similar to the STT Pro but maybe just shy of it as far as aggressiness. In 265/75/16 it only weighs 48 pounds. It's the only E rated tire I would use. Otherwise the Duratracs are good tires (very soft though) in C rated and they are even lighter.
  9. Aug 14, 2017 at 11:54 PM
    PreTaco170
    PreTaco170 Well-Known Member
    Russ
    St. John’s County
    2009 PreRunner DCSB TRD OR
    Bilstein 6112/5160, Dakars, JBA UCAs, FN f(x) Pro 17x8, 285/70R17(C) BFG KO2, Wheeler's Off-Road Bumpstops/U-bolt flip kit, CMC, Marlin Crawler HD LCA Frame Brace Kit, TRD CAI, Flowmaster exhaust, Alpine iLX-407 CarPlay receiver
    Yes but the only 17" size I know about is 255/75R17 and it's 31.77" tall, 10.2" wide, and 55 pounds. There are no 16" listed on their website.
  10. Sep 19, 2017 at 12:42 PM
    Jeepnick
    Jeepnick [OP] Well-Known Member
    Nick
    Pittsburgh
    Bump this
    Having thoughts of buying 17inch 4Runner Sema wheels
    Still wondering what size pro owners are running happily
  11. Sep 19, 2017 at 1:15 PM
    Governor
    Governor Well-Known Member
    Las Cruces, NM
    2016 DCSB TRD OR 4x4
    U trade in the Duratracs before the end of their useful life?
  12. Sep 19, 2017 at 1:42 PM
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    yes i did.
  13. Sep 19, 2017 at 1:44 PM
    Governor
    Las Cruces, NM
    I just put Duratracs on this past Saturday...how many miles did they give you?
  14. Sep 19, 2017 at 1:47 PM
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    10k but there was plenty left. you'll be at 40k-50k use from what i hear.
  15. Sep 20, 2017 at 2:38 AM
    #35
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    275/70/17 on sema rims,, cooper at3's.c-load... not even close to rubbing,,, smoothe ride and quiet,,
    17 in. sr8's matte gunmetal patiently waiting in garage for tire's, they will be my main rims and tires, when i decide on a tire,, leaning towards 265/70/17 ridge grapplers..
    PreTaco170 likes this.
  16. Sep 20, 2017 at 3:11 AM
    #36
    doorsidedown
    doorsidedown Well-Known Member
    285/75/16 Nitto Terra Grapplers Load range D on my pro and I love it (2nd gen though)
    Also had Terra Grappler G2's 17" Pro SEMA wheels on my last truck which I liked better. They don't make 285/75/16 in the G2's so I had to get the original Terra Grapplers for my current setup.
    Either way, you can't go wrong as long as you stay D range or below. Will you notice some impact on MPG or power? Of course, but not enough for me to care. Good luck OP
  17. Sep 21, 2017 at 2:50 AM
    #37
    bludweiaer
    pa
    almost no D range tires, some C rated then they jump to E rated,, wish there were more D options,
