E rated tires vs non E rated
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ptm, Mar 19, 2017.
  1. Mar 19, 2017 at 4:56 AM
    ptm
    ptm [OP] Well-Known Member
    East Coast
    2006 Tacoma TRD
    Magnuson Supercharger Bilstein 5100 w/ OME 887s and 3 Leaf AAL Progressive TRD Quickshift TRD Shifter Knob URD Stage III Clutch URD 3" SS Exhaust Diff Drop Performance Steering Bushings Stealth Custom Series 17" SR8s 285 70 17s Toyo Open Country AT IIs Leather throughout, include leather padded steering wheel, shift boot and armrest HomeTaco Grill
    My suspension setup is a 3 inch lift deploying Bilstein 5100 w/ OME 887 up front and 3 leaf progressive AAL in the back with the stop leaf installed. Most of the tires that I am looking at in the 285 70 17 range are E rated. A few guys I talked with indicated that the E rated tire is too harsh a ride for the Tacoma and suggested that I go with a tire that is not E rated. I want to go with the KO2s but it only comes E rated. I can get the Toyo Open Country IIs in285 70 17s not E rated. Anybody have experience on E rated tires? Any suggested tire brands that manufacture 285 70 17s? Thank you
  2. Mar 19, 2017 at 5:29 AM
    Pigpen
    Dan
    Northwest Montana
    I love my E rated tires, but I abuse them and rely on them. If you wheel hard or travel to remote areas often, they're well worth it.
    DustStorm4x4 and BassAckwards like this.
  3. Mar 19, 2017 at 5:34 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Most comments you'll get are broad strokes answers that lump ALL load range C tire together and ALL load range E tires together. There are no absolutes.
    I HAD load range C Goodyear Duratracs on my truck. To get decent gas mileage and to get even tread wear, they required 36PSI (+)
    I now have Load range E Cooper STT Pro's. I run 28PSI and get even wear, decent mileage, AND a BETTER quality of ride.
    I pounded on the Duratracs with NO issues. Quite a bit of off roading in rocks, slate, shale, etc....Not a mark on them. C's aren't "across the board" weak like some will indicate.
    Circumstances AND choice of which tire you're talking about will have a huge effect on the final answer to your question.
    DVexile, Norton, JayMac and 3 others like this.
  4. Mar 19, 2017 at 5:48 AM
    Pigpen
    Dan
    Northwest Montana
    I ran Cs for years. Never had a problem. A nail will go through almost any tire.
    Bill has a habit of giving good advice.
    I run my 33.5" load Es at 45 in summer and 35 in winter - it gives me the performance characteristics I desire, and evens out the wear (more or less).
    Bluegrass Taco likes this.
  5. Mar 19, 2017 at 6:08 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
  6. Mar 19, 2017 at 8:08 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    love my E rated tires. running game them at 35psi and the ride is great. I went through 4 sets C rated tires in 4 years. I've been on my E's for 5 years 55k miles and still have tons or tread left. granted I don't drive as far for work anymore. I would much rather replace tires due to age then premature wear. I for one will only buy E rated tires from now on
    JayMac likes this.
  7. Mar 19, 2017 at 8:10 AM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    I have the KO2's "E" rating, 285/70/17...love the tires, I don't feel as though they provide a harsh ride, The tires are not loud, they are very smooth, I run 32psi in the summer and 28psi in the winter, very happy with the tires.
    JayMac likes this.
  8. Mar 19, 2017 at 8:10 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    This ^^
  9. Mar 19, 2017 at 8:20 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Gonna add a little more; The load range C Duratracs had 51,000 miles on them when I took 'em off. They had (EASILY) another 25,000 good miles left on them. They were wearing excellent. I've talked to others who wore out the same tire in 30,000. Much of tire life depends on driving style, condition of the truck, your routine maintenance program (ie tire rotation/alignment/etc), even the roads you drive on. And some people are just harder on things than others.... Also, keep in mind rim width can effect tire performance. Just an inch wider can change the footprint considerably in some cases.
    E's or C's are not inherently better or worse for wear than the other.
    And EVERYTHING changes with brand/model of tire, rubber compounds, etc.
    Again, there are NO absolutes.
    DVexile and Norton like this.
  10. Mar 19, 2017 at 8:24 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I get the same mileage with C-Rated 35's (315's) as I did with E-Rated 33's (295's), and they are the same weight wheel and tire combo.
    The 35's I'm running 25psi in the rear and 28psi in the front, with a decent ride.
    The E-rated tires were pretty rough riding on my AC, but I think most of it is because of the stiff valving in the 5100's.
