E15 vs E10 Gas Mileage (No More E15 for me)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Steve Urquell, Apr 28, 2022.
  1. May 11, 2022 at 10:30 PM
    #41
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I steampunked my Tacoma, burning wood in a boiler. Cheaper than gas.
  2. May 11, 2022 at 10:34 PM
    #42
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I agree that for the most part no two tanks are equivalent and observed fuel economy will be all over the chart.
    Observations aside, E 10 has less energy than 100% gasoline per gallon, therefore more fuel will be consumed using E 10.
    I paid $4.50 for 87 octane E10 yesterday. :pout:
    zoo truck and Robnik like this.
  3. May 11, 2022 at 10:38 PM
    #43
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Not if you have a gm flex fuel sensor. It detects the e content and adjusts the AFR and timing maps according to how you set them. E also makes power I'm a wide AFR range. So like in my CTS-V I can tune it exclusively on e without a sensor and it's safe between 60-85%.
    splitbolt[QUOTED] likes this.
  4. May 11, 2022 at 10:39 PM
    #44
    JayRolla
    Colorado Springs
    Yeap. Loss of fuel mileage but can make insane power.
  5. May 11, 2022 at 10:41 PM
    #45
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    I understand what you're saying. Yes, that's an old picture. I'm paying around $4.50 a gallon for regular now.
  6. May 11, 2022 at 11:11 PM
    #46
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Ha. I paid $5.99 a few days ago. Consider yourself lucky!
    If gas was still that price I would consider moving to Florid, scratch that, I ain’t moving to Florida :crapstorm:
  7. May 12, 2022 at 2:18 AM
    #47
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
  8. May 12, 2022 at 4:12 AM
    #48
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    So explain why I get best mpg and most miles out of a tank of premium vs when I use regular my trucks ECU doesn't make adjustments I get ping or knock , shitty mpgs , and least amount of miles per tank at sea level . Educate me.
  9. May 12, 2022 at 5:38 AM
    #49
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Same here. Wouldn't surprise me if the cost of gas goes higher.:frusty:
  10. May 12, 2022 at 6:00 AM
    #50
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    this is a little bit off topic, but I work on small carbureted engines as a side job...
    I absolutely love ethanol in gas!!!
    I've had so much business rebuilding carburetors and fuel systems since ethanol is in almost all of the gas around here. LMFAO
    I've even run ethanol gas in one mower and non ethanol in an identical mower. after maybe 10 tanks of gas, the ethanol mower always needs the carb sprayed out because the white corrosion clogs up the brass jets and builds up around the float hinge.
    eventually the whote crust builds up to where spraying out the carb does not remove it and i have to run wire through the jets. usually a complete carb disassembly and cleaning is necessary.
    it happens in about 1/4 the amount of time in comparison to regular gas.
    using seafoam regularly keeps a carb clean with regular gas. with ethanol gas, seafoam doesn't prevent the white crud.
    TX BAJA1, shotgunbilly420 and Vmax540 like this.
  11. May 12, 2022 at 6:25 AM
    #51
    shotgunbilly420
    Job security buddy lol
    FishaRnekEd[QUOTED] likes this.
  12. May 12, 2022 at 6:29 AM
    #52
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The fuel btu content is the same between 87 and 93 however the ECU vehicle can use it more effectively.
    Old cars didn't have the ability to control the timing dynamically, we set them as advanced as we could without knocking and that compromise was the best we could do.
    The modern ECU both constantly adjusts the timing and monitors for knock, it should be able to advance the timing more to take advantage of the higher octane fuel.
    FishaRnekEd and cryptolime like this.
  13. May 12, 2022 at 6:36 AM
    #53
    zoo truck
    None
    I service many 2 stroke, and 4 stroke carbs also. I've seen the opposite effect on carbs that were run with on fuel with ethanol, their spotless inside. Its older the older fuel pumps, and carbs that were manufactured before ethanol was introduce in gasoline that o rings, and rubber components have been found harmed by the ethanol. Biggest issue with gasoline with ethanol is phase separation where ethanol will collect too much water.
  14. May 12, 2022 at 6:44 AM
    #54
    Vmax540
    Chuck
    Clarion PA.
    I hear you... now not sure, if the fuel makers have changed something in the ethanol blends or people are learning to avoid ethanol in engines that are not driven daily since, I see fewer fuel system issues than I did at first ?
  15. May 12, 2022 at 5:04 PM
    #55
    Steve Urquell
    Steve Urquell [OP] No Pants
    2017 2.7L/5MT AC Utility 4X4
    Well here's how this tank worked out. It had 12% E10 in it so I went ahead and refilled with E15 to check another tank.
    I drove 412.1 miles and put in 19.02 gallons for a mileage of 21.66mpg.
    Surprising to me and I'll keep updating as I go thru the next tank. Hope you find this useful.
    shotgunbilly420 likes this.
  16. May 15, 2022 at 3:02 AM
    #56
    FishaRnekEd
    New Orleans, LA
    i think people have discovered some of the anti-ethanol fuel additives that actually work.
  17. May 15, 2022 at 5:34 AM
    #57
    zoo truck
    None
    Idk, other than your truck doesn't perform like mine. It runs great on 87 regular, far worse on premium. I think my buddies old 2019 trd v6 was the same as yours..it just ran sub par on any grade fuel.
  18. May 15, 2022 at 6:01 AM
    #58
    111R
    111R Well-Known Member
    I use non-ethanol gas in all my mowers and 2-stroke equipment. It’s available at some Quik Trip gas stations here in the Atlanta area.
  19. May 15, 2022 at 6:08 AM
    #59
    shotgunbilly420
  20. May 15, 2022 at 6:10 AM
    #60
    shotgunbilly420
    It's weird I know the first 10,000 miles I broke the motor in on regular gas , the rest of my 147k mi I've used premium.
