E3rz-N73 vs. 3Rz-Fe?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kbrumfield, Feb 9, 2016.
  1. Feb 9, 2016 at 12:09 PM
    Kbrumfield
    Kbrumfield [OP] Member
    Kevin
    i recently bought a used 3rz-n73. I assumed it was a 3rz-Fe because I had never even herd of a 3rz-n73. It's supposedly out of a 97 Tacoma 4x4 5speed. It's in great shape but I was going to use in a 22r to 3rz swap. The only thing I was wondering is how much deferent is the 3rz-n73 compared to the 3rz-Fe??? I can't find much on the motor, other then they only made a few and it's a rare motor :confused:
  2. Feb 9, 2016 at 12:38 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Same thing, mine has that little valve cover sticker too, its just a basic 3rz
  3. Feb 9, 2016 at 12:46 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Is it the models with the old school distributor setup? Vrs the electronic ignition of the FE models.. thats prolly the difference.
  4. Feb 9, 2016 at 12:46 PM
    Speedytech7
    I believe so, but it is still a 3RZ, just different ignition through the years.
  5. Feb 9, 2016 at 12:50 PM
    bry838
    oregon
    Op, a few posts down there is another thread talking about the same thing...might check it out, some info there...
  6. Feb 9, 2016 at 2:03 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  7. Feb 9, 2016 at 2:17 PM
    Speedytech7
    It's just a revision marker guys, the FE part means fuel injected double cam, that's it. So it falls under the category of 3RZ-FE while being the N73 revision.
    45acp and Kbrumfield[OP] like this.
  8. Feb 9, 2016 at 2:17 PM
    Kbrumfield
    Kevin
    Alright, thanks guys. And yes it does use a distributor vs coils.
  9. Feb 9, 2016 at 2:28 PM
    Speedytech7
    No prob, for what its worth you can convert the older distributor models to coils with a newer intake cam and vice versa if you change the head to an older one on the newer models.
  10. Feb 14, 2016 at 1:49 PM
    Kbrumfield
    Kevin
    Hey quick question, does your 3rz use a distributor and if so is it held on by 2 bolt or by 2 bolts and a nut?
  11. Feb 14, 2016 at 3:08 PM
    Speedytech7
    Yeah, mine has a dizzy, I felt around the housing and it looks like the distributor is held to the head with 2 bolts, but there may be one under the cap too.
  12. Feb 14, 2016 at 4:00 PM
    Kbrumfield
    Kevin
    The problem I have is that the motor I got didnt come with a distributor. And the one I got from the parts store doesn't fit because of a bolt/stud that comes out of the head. When I got online I couldn't find any distributors for the 3rz with a 3rd hole for the bolt/stud. I'm not sure what do toimage.jpg
