EAG grill, possibly the first pictures of this one installed.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mistaplow, Feb 6, 2019.
  1. Dec 19, 2019 at 7:52 PM
    #41
    Tacomabaja12
    Tacomabaja12 Well-Known Member
    Oscar
    2012 Barcelona Red TX BAJA TRD
    Do you have a write up
  2. Dec 20, 2019 at 2:20 AM
    #42
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    Mines a 2007, so it's not the same front end, but it's pretty much the same grill
  3. Dec 20, 2019 at 9:24 AM
    #43
    325red
    325red Active Member
    I ended up not using the eag because the mesh wasnt flat enough for letters. I went with custom car grills
    cloudbnd likes this.
  4. Dec 20, 2019 at 10:30 AM
    #44
    Tacomabaja12
    Oscar
    Did you guys keep the seal that came with it, when you painted the surround ?
  5. Jan 1, 2020 at 12:38 PM
    #45
    Ramrod21
    Ramrod21 Member
    2015 TRD Off Road 4x4
    Awesome looking truck! I've been looking at new grills so this post helps a lot, thank you! Is this the same grill?
    EAG Replacement Grille Black Stainless Steel Wire Mesh with ABS Shell Fit for 12-15 Toyota Tacoma https://www.amazon.com/dp/B07GF4D5TD/ref=cm_sw_r_cp_apa_i_r8pdEbZ6NXZH9
    #45
  6. Sep 3, 2022 at 9:05 AM
    #46
    Hensloppy
    Hensloppy Active Member
    Henry
    Lagrange, GA
    2007 White Tacoma Prerunner
    Has anyone tried swapping to white lights on the grill? Im curious to see if the lights are swappable?
  7. Sep 4, 2022 at 5:16 PM
    #47
    Onespruceduptaco
    Onespruceduptaco Well-Known Member
    Brian
    Santa rosa, CA
    2014 tacoma trd offroad
    Prisnu roof rack Voodoo bed rack Coastal low pro rear bumper Diode damn ssc2 reverse light kit Diode dynamic interior kit Kenwood excelon door speakers Weather tech floormats 6112s 700lb springs Expedition 3" springs
    The one I did I painted the new shroud
