eagle alloy 137 fitment??
Discussion in 'Wheels & Tires' started by Gabe911, Feb 17, 2012.
  1. Feb 17, 2012 at 11:23 AM
    Gabe911
    Gabe911 [OP] Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    http://www.tirefactory.net/Eagle137SfBlk.html
    I am pretty sure these will fit ...the numbers are slightly different than the procomp or xd's but I like these too. 4.625 BS +6mm offset 16x8 vs the pro comps 16x8 0mm 4.5 bs
    How does the offset change anything from my understanding it will tuck the wheel under the fender slightly vs a -neg offset pushes it out...I know the backspacing is good at 4.625 anyone running these onn here any comments??? thanks
  2. Feb 19, 2012 at 12:38 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Offset is simply a number that's calculated from wheel width and backspacing. You are right the the lower the offset, the more a wheel with stick out
