Ear Protection from Lawnmowing/yard work
Discussion in 'Off-Topic Discussion' started by 169.254.255.201, May 30, 2013.
  1. May 30, 2013 at 9:09 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Outdoors, one or the other.
    Indoors, it depends on what the people in the other lanes are shooting.
    Normally, just the amplified/suppressing muffs. That holds me just fine up to my .45. The .357 is a little hot, but I'm not putting 300 rounds through it like I do the 9mm's and .45.
    If someone shows up with a Desert Eagle, or a large-caliber revolver, then I step out and add plugs under the muffs.
  2. May 30, 2013 at 10:29 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    From an OSHA standpoint...anything over 85db is required to wear ear protection. I wear earplugs EVERY day where I work. We get tested yearly for changes in our hearing. I already have a hearing aide in my left ear (not from work or noise).
    I use foam expandable earplugs. My employer carries a lot of different types. I wear the 3M E-A-Rsoft yellow neons. They're soft and comfortable for my little ear canals.
  3. May 31, 2013 at 2:37 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    The in ear foam ones are the best I've found. Add to this the over the ears (Muff Style) ones and your ears will be perfectly safe.
    These are the exact ones I use.
  4. May 31, 2013 at 3:58 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    respectively disagree
  5. May 31, 2013 at 4:09 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I use the 3M in ear disposables from Lowes. I work in a moulding shop so a planer running or a 5 head moulder running get loud. It's loud enough I can only stand a couple minutes without earplugs before I get a headache. I don't mind wearing earplugs at all. I like my hearing. OP ignore anyone who says you do not need earplugs. Never hurts.
  6. May 31, 2013 at 4:14 PM
    andjenliang
    andjenliang Well-Known Member
    Andew
    LBC/OC/LAX
    10 DCSB PreRunner V6 TRD Off Road
    Stock
    I always have a pack of these tucked away all over my house, thriftytip you can put these into those mesh laundry bags and wash them, then air dry. I use these when i go shooting and using my 2 cycle string trimmers. There is also this type of ear protection which are just ear plugs on a plastic head band. they look like the old school headphones except with ear plugs.
    Yea always wear ear protection, long exposure to loud noises eventually leads to deafness of certain frequency ranges. It sucks even to be hard of hearing, people have to keep repeating things to you and it leads to communication issues.
  7. May 31, 2013 at 5:10 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I have a metal pin in each ear that replaces the stapes (small bone). $40,000 in surgeries to fix otoschlerosis, under $4000 out of pocket. It's hereditary, you cant cause it through loud noises. My hearing was down to -65. When the day came to give in and get hearing aids, I was LUCKY to get the news that surgery would fix it. I got most my hearing back, But its still -20 or so, it cant all come back.
    Accumilative exposure to loud noises cannot be repaired, you wont get to simply fix hearing loss from high noise.
    You wont know the hearing loss. Then one day 10 -20 years later you finally realize it crept away so slowly you never noticed it. You wont notice it go, you wont get it back. Your little hairs things in the ears will be toast gone and non repairable.
    If the worst you do is mow the lawn for 30 minutes, most people will be fine. I suspect some people aren't as resilient as others. I just ask if you have any doubt, try some muffs or plugs. Seems like nothing at 20, but by 40, you could regret the minor sins of the past.
    ps , lost a girlfriend, she would NOT GO UNHEARD!! also became a comedy expert on " heard the wrong thing... like hearing the word "factor".... "fucked who???"
    sorry for yet again another long post. Hope it helps though.
  8. May 31, 2013 at 6:01 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
  9. May 31, 2013 at 8:14 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I only double up for magnum calibers (300 win mag +)
    PPE is mandatory.
    I recently suffered some loss after a flashbang went off in a room i was in. Even with my peltors on, it still fucked me up.
  10. May 31, 2013 at 10:58 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It's amazing how quickly it can happen.
    Probably 25% (or more) of my loss was due to ONE afternoon in the desert when my buddy forgot to bring the Peltors for his son. I let him use mine, and figured a piece of tissue wadded up would be good enough.
    The first shot with the .45 revealed otherwise.
    I excused myself back to the truck when we were shooting anything more than the 9mm or .38. My ear (I've been totally deaf in my right ear since '74) rang for weeks, and in the last 10 years, the ringing has become increasingly worse.
    For those who don't think hearing protection is a big deal, check this out...
    http://www.ata.org/sites/ata.org/files/media/ATA_Tinnitus_Tea_Kettle_Tone.mp3
    That noise is in my head 24/7.
    Along with that, if my wife "clinks" two plates together stacking them anywhere within about 4 feet of my left side, it is painful. Same thing if a soda/beer can is opened in the same distance. I have grown used to opening cans on my right side, so it is tolerable in my left (working) ear.
