Early 1st-Gen Disc Brake Question
Discussion in 'Technical Chat' started by scoostraw, Apr 17, 2013.
  1. Apr 17, 2013 at 9:29 AM
    scoostraw
    scoostraw [OP] Well-Known Member
    Ken
    Wisconsin
    1995 Tacoma 4x4 Ext Cab 6cyl 5-Speed
    One front caliper on my '95 has begun to seize up, so I'll be replacing it soon. From reading, it appears to me that the early - 95-96 (97?) - tacos had a different front disc design.
    It looks like that to replace the rotor on my 95, the hub bearing must come off. While on later 1st-gens the disc is just held on with the lug bolts.
    Am I right on this? Are the calipers the same - and just the rotor/hub design changed? (I definitely have a 4-piston caliper)
    '95 4x4 SR5 Extended Cab V6 5-Speed
  2. Apr 22, 2013 at 4:23 PM
    scoostraw
    Ken
    Wisconsin
    I answered my own question today as I replaced the bad caliper. The rotor came right off (held in place by the lug nuts).
    So the online Autozone repair guide as well as the chilton manual are both incorrect, which is good to know.
  3. Apr 23, 2013 at 5:41 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    ^You're right and I'm glad you got it figured out.
