early 97 instrament cluster
Discussion in '4 Cylinder' started by reef165, Jan 5, 2013.
  1. Jan 5, 2013 at 2:03 PM
    reef165
    reef165 [OP] Member
    portland oregon
    97 ec tacoma 4x4
    leveling lift, 33 inch tires
    Hi, my name is Eddie, I just joined this site, I have lurked here a couple times and love it!
    Now, to the mater at hand. My speedo went out on me, and from what I gather the instrament cluster I have is quite rare, it is pre 6/97 and has a tack, all I can find is a tackless cluster and am wondering if posable and how hard it would be to get a tackless cluster and remove the speedo from it and fix the speedo on the cluster I have.
  2. Jan 10, 2013 at 8:51 PM
    BamaToy1997
    Bill
    Navarre, FL
    Have you verified that the speedo is what has failed? You have a cable that runs to it from the transfer case. I would verify that the cable is working properly before looking at replacing the cluster.
  3. Jan 11, 2013 at 8:24 AM
    reef165
    reef165 [OP] Member
    portland oregon
    97 ec tacoma 4x4
    Ya, I had to replace my heater core, so while in the prosses of doing that I had ordered a speedo without tac from ebay, I realised after getting the heater core done and taking it for a test drive to warm it up without the cluster in stalled that the speedo cable wasn't turning, now gotta spend another $100 on a cable on top of the $75 for the cluster I didn't need, wasn't a tottal loss though I needed a couple light bulbs and the lense on mine was cracked so I traded that out for the one I got.
  4. Jan 11, 2013 at 11:12 AM
    BamaToy1997
    Bill
    Navarre, FL
    Check at the transfer case. Disconnect the cable and manually turn it while someone inside is looking at the cluster end. A broken speedometer gear can also cause the cable to not turn. Verify before EVER ordering a part.
