Early Morning 3rd Gear Grind
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05DoubleTaco, Nov 9, 2008.
  1. Nov 9, 2008 at 6:59 PM
    05DoubleTaco
    05DoubleTaco [OP] Well-Known Member
    Maryland
    2005 Lifted DoubleCab
    3" Toytec Lift, 285/75/16 Cooper STT, Moto Metal 951 Wheels, Magnaflow Exhaust, K&N Intake, URD MAF & Tune, Full Stereo w/ Marv Custom Box
    My first shift into 3rd every morning will grind. Just a little, nothing major... I've found that if I take it real slow, press the clutch in and slowly and easily slip it into 3rd it wont grind.
    Just wondering what your thoughts are?
    I've been thinking about changing the tranny fluid to synthetics, sounds like a good start.
    I'm not really worried about it, just curious.
  2. Nov 9, 2008 at 9:05 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Switch it to Amsoil tranny lube and be done with it :D
  3. Nov 10, 2008 at 6:17 AM
    05DoubleTaco
    Maryland
    I have a week off at the end of the month.
    I'll let you know how it works out.
    I'm switching the plugs over at that time as well. Getting a full tune-up! The truck is getting ready to sit, as I now have an Altima for everyday driving. About time to give the Tacoma a break, 2005 with 84K!
    Anybody have the right type of fluid needed and how much for the 6spd?
  4. Nov 10, 2008 at 6:48 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2017 dcsb trd offroad blazing blue pearl
    yes switch to synthetic tranny lube. royal purple is my vote but all the above are great as well. it is the synchro in the tranny that is not lining up smoothly.
  5. Nov 10, 2008 at 9:11 AM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
    Same here, every morning or whenever the truck is cold 3rd gear will grind. As you say, if I'm paying attention I can avoid it.
  6. Nov 10, 2008 at 9:18 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    Mine did that with 3rd then 4th them my trany blew! hope it is not the same problem! i was at 140,000 HARD miles!
  7. Nov 10, 2008 at 9:22 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    I put synthetic oil in my old truck and it was amazing difference i will be putting synthetic in my 2008 this weekend if time allows!:D
  8. Nov 10, 2008 at 5:02 PM
    Gerry Pope
    Gerry Pope Well-Known Member
    San Diego
    07 4X4 PreRunner
    I had pretty much the same problem.. All other gears were smooth as butter.. 3rd was a pain.. Would go in fine then next time it would do the bump n grind.. After reading about the fluids folks here used I changed out the tranny fluid with Red Line MT90.. I was a little skeptical at first.
    Took it for a spin after the fluid change and was very pleased with the results. 3rd gear is now flawless.. Hope it works out for ya..
  9. Nov 10, 2008 at 6:11 PM
    wawireguy
    wawireguy Well-Known Member
    Doesn't have squat to do with tranny lube.. Has to do with RPM vs gear. The RPM is off for engaging that gear. Whether there are other factors I don't know. Personally I don't like syncromesh and wish it didn't exist. Your tranny might be screwed up but basicly you need to be at the correct RPM for that gear to engage properly.
  10. Nov 11, 2008 at 7:06 AM
    allrsdup
    Sahuarita AZ.
    it does make sense good lube makes everything slide in easier..:D
