early or late 1st gen ???
Discussion in '1st Gen. Tacomas (1995-2004)' started by juice, Sep 20, 2010.
  1. Sep 20, 2010 at 3:00 PM
    juice
    juice [OP] Member
    covington,la.
    03 sr5 xtra cab trd
    Hey guys, i'm looking for a 1st gen ,and was wondering how the 95',96',97' years compare to the later years 03' and 04's?? I know to be aware of frame rust. Are the drive trains/motors all the same? the I found a 97' with a 5 speed v6 with under 100,000 miles. they are asking 9,000. what are y'alls opions??? thanks for the info!!!
    GQ7227 likes this.
  2. Sep 20, 2010 at 3:50 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The drivetrains are all the same (for the most part).
    I'd get the newest one that you can afford and definately have it checked for the frame rust by a toyota dealer before you buy.
  3. Sep 20, 2010 at 7:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The '97s are great trucks. Every bit as durable as later model 1st gens. Mileage is low for the model year but not too low. Can't really go wrong.
    About the only real drawback that I can think of on the '95.5-'97s were their headlights. The old, sealed beam type. They aren't very good compared to halogens of the '98s and newer.
    GQ7227 likes this.
  4. Sep 20, 2010 at 7:47 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    Most are all small changes
    95-97
    98-00
    01-04
  5. Sep 20, 2010 at 7:58 PM
    juice
    juice [OP] Member
    covington,la.
    03 sr5 xtra cab trd
    Thanks for the input!:D the 1st gen tacoma are so dam expensive! Its hard to find a decent mileage tacoma in good shape down here in south louisiana!!
  6. Sep 22, 2010 at 5:45 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    As mentioned, the 1995.5 - 1997 headlights don't stack up well against the later ones.
    With a pre-'98 Taco you have to deal with some older technology like:
    - distributor (4-cylinder models)
    - cable-driven speedometer
    1997 is the earliest year that can really use a TRD supercharger, because the earlier ECM's couldn't keep up with fuel mapping data shifts.
  7. Sep 22, 2010 at 8:52 AM
    scocar
    scocar Patron of the Farts
    The interior is a little more refined in 01-04.
    For 01 and 02, ABS became an option
    For 03 and 04, ABS became standard
    I didn't want ABS, and I am happy my 01 doesn't have it...just thought I would mention it if you care.
    I think there is more throttle-by-wire stuff in the 03-04, too, but I may be revealing my ignorance here...someone with better info/experience can chime in. I dont' have time to dive into the 2003 FSM at them moment.
    GQ7227 likes this.
  8. Sep 22, 2010 at 7:35 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I'm pretty sure mine is a straight throttle cable. I can feel the play in the pedal while in cruise control, so there's definitely a physical link there.
  9. Sep 22, 2010 at 8:17 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Early 1st gen V6 models had head gasket problems as well, but I don't think think as bad as the 3.0L engines.
  10. Sep 22, 2010 at 8:31 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    i have a 95 with 196k and running perfect, the interior is super quiet.
    ohh headgasket? never heard of it in a Tacoma
  11. Sep 22, 2010 at 8:33 PM
    747 function > form
    1st Gen.
    i've heard that '03 was the best model year ever...just sayin'.
  12. Sep 22, 2010 at 9:26 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I vote 01-02, preferably 02. :D
    03-04 does have a semi throttle by wire system but it not the full blown ETCS like on the 2nd gens
    IIRC it was the pre-tacos (Toyota p/u) v6s that were known for head gasket issues.
  13. Sep 22, 2010 at 9:30 PM
    Finks99Taco
    Finks99Taco Well-Known Member
    'Fink'
    Coconut Creek, Florida
    1993 pickup
    I have a '93 and a '99 and LOVE them both.
    I bought the '99 last year with 94K miles for $6,000.
  14. Sep 22, 2010 at 9:32 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    I blew my head gasket a while back, but it was due to the coolant being frozen and the engine not having any coolant running through it. Otherwise, it wouldn't have blown, at least not the way that I drive it.
  15. Sep 22, 2010 at 10:11 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The '02 Tacoma was the pinnacle of achievement. :D Toyota's finest hour.
    Besides, everyone know that the '03 and '04s were built from left over '02 components. Just Sayin... :eek:
  16. Sep 22, 2010 at 11:15 PM
    scocar
    No no no, you have it all wrong, 01 Silver Xtra cab V6 4wd TRD SR5s in lunar mist metallic are the standard by which all others are measured, especially if they have had their crappy stock suspension replaced....just sayin'. :headbang: 02s are just imitations...
  17. Sep 22, 2010 at 11:17 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I like the 2004s the best...I used to own one :D
  18. Sep 22, 2010 at 11:19 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    you guys are all wrong, the mighty 95 is the father and creater of all Tacos! "just sayin"
  19. Sep 22, 2010 at 11:35 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    Because of the electronic changes noted above I would go with a 98 or newer. At that point in mileage though I would be looking pretty close at this truck before you buy it. There are a fair number of components that are designed to last about 100k.
  20. Sep 22, 2010 at 11:45 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    I had a 03 5spd and now I own a 02 auto. Both were and still are bad ass. I do wish I had the abs on my 02.
    Other than that I did like the fender flairs on the 03 better. They were a little bigger, so I thought. idk maybe I am wrong, I just remember them lookin bigger!
