Earring in the vent.... Need suggestions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jabrackin, May 15, 2012.
  1. May 15, 2012 at 6:14 PM
    jabrackin
    jabrackin [OP] Well-Known Member
    Knoxville, TN
    2008 TRD OffRoad
    One of my wife's earrings went through the top windshield defroster vent and now when I make turns, it can be heard going from side to side in the vent. Any idea on how I can get it out? It is annoying as crap.
  2. May 15, 2012 at 6:18 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Shop vac necked down to a soda straw or long plastic tubing, depending on how far down it is.
    It'll either stick to the end or get sucked in where you can retrieve it.
  3. May 15, 2012 at 6:19 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Just turn the truck upside down and shake it...
  4. May 15, 2012 at 6:29 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    I don't know, I think it is in pretty deep because when I am drivi g and turning, you can hear it going side to side.... I thought it sounded like a rock at first, but she told me she had set them up on the dash. I took the radio out and looked from side to side, but I couldn't see anything.
  5. May 15, 2012 at 6:29 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    We used to joke about that being the Kawasaki factory procedure to remove the battery from a Vulcan 1600.
  6. May 15, 2012 at 7:50 PM
    cooktaco
    cooktaco Well-Known Member
    Northern California
    11 Dbl. cab TRD 4x4
    Weahertecs, Bed met, Snugtop, Avid sliders, TSB Springs, Bilstein 5100's @1.75,
    +1 on the vacuum. I dropped a small nut and washer down the vent. Macgyver'd some small diameter plastic tubing to the end of my shop vac with duct tape and fished it down the vent. Moved it around a while and sucked both of them into the shop vac.
  7. May 16, 2012 at 2:10 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    small grabber tool(claw)
  8. May 16, 2012 at 2:17 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Use double sided sticky tape wrapped around the sides of a few straws about one inch. Do not tape end. Stick the straws in the vents and leave it there. Drive around, turning until you don't hear it rolling around in there. Hopefully it will stick to one of the straws and you should be able to pull it up.
  9. May 16, 2012 at 2:24 AM
    dfrugia
    dfrugia Well-Known Member
    Goose
    Roswell, NM
    2012 DC TRD OFF RD 4X4
    Running boards w/steps, Weathertechs
    What were you two doing that caused her to lose her earring up there???!
  10. May 16, 2012 at 1:54 PM
    6spd
    6spd Well-Known Member
    san diego
    2012 4x4
    Mechanical fingers. Or you could probably access it from removing the glove compartment. Consult a n hvac diagram to see where you think you hear it.
  11. May 16, 2012 at 2:03 PM
    dfrugia
    Goose
    Roswell, NM
    Telescopic magnet
  12. May 16, 2012 at 2:14 PM
    Aw9d
    Aw9d That one guy
    Az
    Only work on some metal objects. If they are gold then that won't work.
    I like the shop vac idea.
  13. May 16, 2012 at 2:29 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Me thinks earings got air born during in-car exercise activities... :cool:
  14. May 16, 2012 at 3:56 PM
    boshak
    boshak Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
    Plus double sided tape :)
  15. May 16, 2012 at 5:25 PM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    Get boroscope and find where it is, then use the sticky straw or shop vac idea!
  16. May 16, 2012 at 6:13 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Bought our condo from a nice Mormon couple.
    Moved in, turned on the ceiling fan in the dining room.
    Off from the top of the fan flies a very frilly crotchless g-string... definitely not standard issue Mormon underwear!
