Easier Fix for Blower Motor Squeak!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Traveler, Jul 26, 2012.
  1. Jul 31, 2012 at 7:14 AM
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
  2. Jul 31, 2012 at 11:34 AM
    testedone
    Rick
    U.S.A.
  3. Jul 31, 2012 at 11:51 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    The chirp is a brush alignment issue. W-40 will be a short term fix. A little lube on the bearings helps also. But the real fix is re setting the brushes when you install the metal motor end cap.
  4. Jan 24, 2022 at 7:37 AM
    NickG328
    NickG328 New Member
    Can you provide a link to "this other thread"? Cant find it but would like to understand better how to adjust the brush screws (if that's what you're referring to).
  5. Jan 24, 2022 at 7:43 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The thread I used no longer has the photos in tact, unfortunately. This thread is a pretty in depth look at the blower motor assembly. If you look at the second photo in this thread, you'll see the bottom of the blower motor assembly and the 2 set screws. Or, you can go whole hog into this repair and completely disassemble and repair.
    https://www.tacomaworld.com/threads/how-to-fix-blower-motor-chirp.142308/
  6. Jan 24, 2022 at 1:55 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I know this is a 10 year old thread, but I have to respond to this. WD40 was designed to be used to safely flush water out of electrical motors and other components.
    It is not a great lubricant however. But used inside an electrical motor probably isn't a bad choice for a temporary fix.
