easier to replace balljoint or UCA?
Discussion in 'Technical Chat' started by YumaTRD, Feb 25, 2011.
  1. Feb 25, 2011 at 9:26 AM
    YumaTRD
    YumaTRD [OP] The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    I am going to replace my OEM UCAs for a newer set of OEM UCAs with lower miles.
    the boots on my UCA are torn and i fear that the balljoints have been damaged by a previous spacer lift. I already have the replacement UCA.
    I am debating if it will be easier if i just replace the balljoint, instead of replacing the entire UCA's?
  2. Feb 25, 2011 at 10:46 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Bump
    Someone who's done the camburg balljoint uca' should have some thoughts on this?
  3. Feb 25, 2011 at 2:28 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
  4. Feb 25, 2011 at 2:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Easier to replace the whole UCA.
  5. Feb 25, 2011 at 2:35 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Cool
    thanks!
