Easier way to replace coolant bypass
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kgbrev, Mar 5, 2024.
  1. Mar 29, 2024 at 9:39 AM
    #41
    eurowner
    eurowner Duke Sky
    Scoty
    Correct.
  2. Mar 29, 2024 at 10:02 AM
    #42
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I wasn’t risking putting on a different part after all the work to get to the bad one… figured I have better odds at the new one lasting longer than 85k.
    jmneill and Kgbrev[OP] like this.
  3. Mar 29, 2024 at 10:16 AM
    #43
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Metal components that come in contact with coolant don’t fair as well in the end. They get eaten up bad.
    Begs to differ why it’s not happening to the other plastic coolant components. As some have said, a design/manufacturing defect. However, that leads to this. And it may help for its longevity.
    The best maintenance practice has to be what a member mentioned a couple months ago. He said that coolant turns caustic. Toyota says to swap the coolant every five years, per tech. It doesn’t cost much, and am thinking of doing it every 4. It was easy to see the tone and tint (for example) in the pink coolant from used to new. It was considerably different.
    Kgbrev[OP] likes this.
  4. Jun 12, 2024 at 9:53 PM
    #44
    Kgbrev
    Kgbrev [OP] Well-Known Member
    2020trdoffroad
    Diamondback SD cover
    I figured it's easier for me to just replace it once ever 3 years or 30 when I do the transmission fluid and diff.
  5. Jun 13, 2024 at 6:01 AM
    #45
    Karpata
    Karpata Well-Known Member
    Art
    2017 TRD Off Road
    Just wanted to update from my late March entries. I did have the coolant bypass pipe replaced by an independent shop, not the dealer, who does work on our vehicles. They completed the job with no issues. I did replace the old pipe with a new one, same design, etc. Knocking on wood somewhere when I say this but so far all is well, no leaks, no issues !!
    Canadian Caber and JmsWms like this.
  6. Jun 13, 2024 at 6:26 AM
    #46
    JmsWms
    JmsWms Well-Known Member
    Jim
    Tennessee
    2017 Inferno TRD Sport AC 4x4
    Do you know how they approached it? Dropped the transmission? From the top? etc.?
    Also, how much did it end up costing you?
  7. Jun 13, 2024 at 6:31 AM
    #47
    Karpata
    Art
    2017 TRD Off Road
    Yes, they did it from the top, removed manifold, etc. Cost about $1250. I posted that awhile ago on another thread on TW about the coolant pipe, and most agreed that price was in line for the job. It was just something I didn't/couldn't do myself anymore.
    Barsoom, JmsWms and eurowner like this.
  8. Jun 13, 2024 at 10:00 AM
    #48
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Im replacing my chewed up anti knock sensor wiring harness next month. Will be checking out that access to to the coolant pipe when I’m in to it.
    JmsWms, Barsoom and eurowner like this.
  9. May 16, 2025 at 5:21 AM
    #49
    Kidneypunch
    Kidneypunch Active Member
    Ethan
    2021 TRD Sport
    Well, I am getting both parts and I am going to try to use the aluminum one. If I cannot I will put in the plastic one. I am going to access by removing the manifold. It is likely I will have to tilt the motor forward by jacking the tranny/transfer case. A shop quoted me $1250 but I think I can do it. Once I get the parts I am going to go to the parts shop and get hoses that will route to the heater line and use a nipple to connect the two. I think it’s stupid they designed it this way as the previous models use metal, and the failure rate makes it so obvious. I tried to reach out to Jowett but no reply. He has stated in threads that he put it all in storage and has not gotten back to it. Bummer. I’ll see what I can do. I saw in a TSB for misaligned coolant pipe that the manifold-mounted port injector fuel supply lines don’t even need to be disconnected as it is just laid over to the side. I still may disconnect.
    Wish me luck, y’all.
    JmsWms likes this.
  10. May 16, 2025 at 5:24 AM
    #50
    Karpata
    Art
    2017 TRD Off Road
    Good Luck. Let us know how you made out !!
  11. May 18, 2025 at 10:34 AM
    #51
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    For $1200 I'd let them do it! I'm cheap, but for the amount of time and the stuff I'd break along the way (or the inevitable special tool I would need) that price is a no brainer for me! Let us know how it goes!
    danielgonzzz, eurowner and JmsWms like this.
  12. May 18, 2025 at 11:16 AM
    #52
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    xBloodxLinex and Canadian Caber like this.
  13. Jun 17, 2025 at 8:54 AM
    #53
    Kidneypunch
    Ethan
    2021 TRD Sport
    I am cheap too. This was above my level. I paid them to do it. They were able to make it work with the Aluminum part. Thanks to Jowett and Japanese Auto Works in Kona! Super nice people.
    BabyBilly likes this.
  14. Jun 17, 2025 at 9:03 AM
    #54
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 Pro
    Any pictures of the new aluminum part installed?
  15. Jun 17, 2025 at 9:33 AM
    #55
    TRD493
    Dave
    Texas (DFW)
    I didn't know there was an aluminum part that was compatible!? I remember that Jowett was possibly working on it at one point in time.
  16. Jun 17, 2025 at 9:48 AM
    #56
    eurowner
    eurowner Duke Sky
    Scoty
    :worthless:
  17. Jun 17, 2025 at 8:29 PM
    #57
    Kidneypunch
    Ethan
    2021 TRD Sport
    That’s right. He was. And he stopped before anything could be finalized. I used the info to get the part and had a mechanic trim a silicone elbow to mate it up. No more leak so far. I did not get any photos but when I have time I’ll get a scope in so I can get a few pics this weekend. But, so y’all know, it works. This is the elbow we used. I supplies the part and the seals and they got me a new manifold gasket set. Total charges was $633.
    https://www.amazon.com/dp/B0CYBPL38Q
  18. Jul 17, 2025 at 8:22 AM
    #58
    shadesbro
    shadesbro Well-Known Member
    keeping an eye on this thread hoping I don’t need it
  19. Sep 9, 2025 at 9:34 AM
    #59
    Billy050302
    Billy050302 Member
    William
    2017 Tacoma TRD Sport
    r3sistance, Barsoom and tonered like this.
