Easiest, best, cheapest 2011 DC Prerunner lift
Discussion in 'Suspension' started by Jdd1091, Jan 20, 2013.
  1. Jan 20, 2013 at 11:09 AM
    Jdd1091
    Jdd1091 [OP] Active Member
    Hey everyone, great info here.
    My son is getting his mom's 2011 DC Prerunner.
    We want to raise the truck 2"-3".
    Street only, a few dirt roads.
    What's the best / most affordable way to raise & level the truck?
    So many choices it's confusing.
    Want to keep the ride the same.
    I had the Daystar leveling kit on my last 2 Dodge Rams without any issues.
    I have a set of 18"x9" Black Rhino wheels and was looking at getting 275/65/18 tires.
    Will this size tire fit ok with a 2" lift? They are +12 backspace.
  2. Jan 20, 2013 at 12:01 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Bilstein 5100s are your best bet for an inexpensive but still decent lift.
    I have 275/65/18s on 18x9s with +10 offset, 5100s at 1.75" lift, and I had to trim to avoid rubbing.
  3. Jan 20, 2013 at 12:02 PM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    if its only seeing dirt roads and absolutely no major offroad and trails excessive bumps just get a spacer lift.
    it will not hurt a street truck. 60 bucks, easy to install, and it gets the job done
  4. Jan 20, 2013 at 12:04 PM
    KPT
    09 Prerunner
    The 5100s I mentioned above are only $180, will offer a better ride than spacers, and will not have any risk of damaging the ball joints or bottoming out the shocks.
  5. Jan 20, 2013 at 12:10 PM
    Jdd1091
    no off roading but the streets in Louisiana SUCK.
    The Bilsteins are $180 but can I install them myself?
  6. Jan 20, 2013 at 12:12 PM
    KPT
    09 Prerunner
    If you are comfortable using a spring compressor. Otherwise you can bring the assembly to a shop and they can disassemble and reassemble the coilover assembly for a small fee.
    If you want to see what 275/65/18s with the 5100s at 1.75" of lift look like, click on my signature.
  7. Jan 20, 2013 at 12:18 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Yes you can & there is even a thread or two on how to do it without a spring compressor.
  8. Jan 21, 2013 at 12:56 PM
    Jdd1091
  9. Jan 21, 2013 at 1:13 PM
    KPT
    09 Prerunner
  10. Jan 22, 2013 at 5:23 PM
    Jdd1091
  11. Jan 22, 2013 at 6:37 PM
    KPT
    09 Prerunner
    Yep both of those are good options. The first one will ride smoother.
  12. Mar 28, 2013 at 7:12 PM
    Jdd1091
    Well I did it.
    Daystar 2 1/2" lift
    Black Rhino 18x9 - 0 offset
    Cooper Discovery At 275x65x18
    ZERO rubbing
  13. Mar 28, 2013 at 7:21 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Where are you located at in Louisiana?
  14. Mar 28, 2013 at 7:28 PM
    Jdd1091
    Mandeville
  15. Mar 28, 2013 at 7:28 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Lol total opposite of what Keith told you
  16. Mar 28, 2013 at 7:31 PM
    Jdd1091
    His way may have been better but mine was cheaper.
    The kit was $115.
    My son and I installed it in about 2 hours.
    Can't tell the difference in ride.
  17. Mar 29, 2013 at 9:29 AM
    KPT
    09 Prerunner
    You won't be able to tell the difference in ride with a top plate spacer. I wouldn't take that thing off the road, or over any speed bumps quickly though.
  18. Apr 1, 2013 at 1:12 PM
    Jdd1091
