Easiest Fastest Way to Set a Fence Post
Discussion in 'Garage / Workshop' started by surfsupl, May 19, 2013.
  1. May 19, 2013 at 8:42 PM
    surfsupl
    surfsupl [OP] Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
  2. May 20, 2013 at 10:02 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  3. May 20, 2013 at 10:20 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That's cool stuff! I have a fencing project, I might have to do a bit more research on this option. I was going to just do concrete.
  4. May 20, 2013 at 10:30 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    as painful as that was to watch, cool stuff..
  5. May 20, 2013 at 12:09 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  6. May 20, 2013 at 12:22 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    That is such bullshit. Who dug the holes, with what. Set the post up into the cement, no air or rotting, what bullshit .
  7. May 20, 2013 at 12:24 PM
    Pugga
    Massachusetts
    Looks like a power auger was used to dig the holes. How is it bullshit, what's easier, a quart of liquid that you shake and pour into the hole or mixing concrete to put in the hole? Depending on the cost of this stuff, I'd give it a shot. The exaggeration on the posts rotting is crap though.
  8. May 20, 2013 at 12:28 PM
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    Seems like a cool product, but it has to be alot more expensive than concrete.
  9. May 20, 2013 at 12:30 PM
    Gearheadesw
    Davenport Fl
    If someone came and dug the holes, supported the post, leaveled everything perfect, I'm fairly certain I could mix concrete and pour the holes as fast as they did. Not just 3 f'ing holes, a whole fence line of holes.
    Cement = proven results,
    chemical whatever that is... is what in 20 years. Gone?
  10. May 20, 2013 at 12:31 PM
    BLKTRD6SP
    BLKTRD6SP Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    Found on garage journal site:
    sold per gallon, complete kit includes all necessary mixer cups, stirrers etc.
    $26.00 per gallon (two parts)
    yields with 8" x 24" deep hole, 5-6 holes
    best used when temps are above 5o degrees for maximum expansion
    closed cell, no water absorption
    can fill vinyl fence posts
  11. May 20, 2013 at 12:33 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    hmm... why not just use a can of expanding insulating foam then?
  12. May 20, 2013 at 12:35 PM
    Gearheadesw
    Davenport Fl
    80lb bag of cement=$4, can do 2 post's
    It does set up faster, letting a person start the fencing a half a day earlier.
  13. May 20, 2013 at 12:51 PM
    Pugga
    Massachusetts
    I think you're missing the point. This would be a quicker process than concrete and you can mix small batches at a time to only set the post you're working on at that moment. Gives you time to set the post, make sure it stays square and plumb before mixing the product for the next one. This product is not going to replace concrete, it's not meant to. All you're relying on this product to do is fill an air gap between the post and the dirt. Poured rubber would yield similar results.
  14. May 20, 2013 at 12:56 PM
    Evil Monkey
    Robert
    Escondido, CA
    Quikrete sells concrete you can just pour in the hole dry and fill it with water.
  15. May 20, 2013 at 1:09 PM
    Gearheadesw
    Davenport Fl
    I guess I'm on the rag, sorry
  16. May 20, 2013 at 1:21 PM
    OZ-T
    Peter North
    British Columbia
    Concrete rots wooden posts
    /discussion
  17. May 20, 2013 at 1:22 PM
    OZ-T
    Peter North
    British Columbia
    You can do that with any " just add water " concrete mix but the product you are referring to is called " Post Haste "
  18. May 20, 2013 at 1:24 PM
    OZ-T
    Peter North
    British Columbia
    I wonder how difficult trimming excess would be from the top of the hole , if it is the consistency of 4lb spray foam that's pretty damn solid
  19. May 20, 2013 at 1:26 PM
    Gearheadesw
    Davenport Fl
    Yes it does OZ, but lift the bottom of the post up into the cement, and build a little mound of concrete around the post at the top. No real water problems, no speeded up rotting. Still on the rag
  20. May 20, 2013 at 1:29 PM
    Pugga
    Massachusetts
    Concrete*
