Easiest install sounds upgrade?
Discussion in 'Audio & Video' started by Bennelson17, Nov 14, 2024.
  1. Nov 14, 2024 at 1:16 PM
    Bennelson17
    Bennelson17 [OP] New Member
    Ben
    2016 Limited Tacoma
    Tonneau Cover
    Hi guys, so my 2016 limited Tacoma was totaled last week and I picked up a 2021 TRD off-road this week. I was used to the much nicer JBL sound system and subwoofer in the limited and would like to upgrade the sound in this 2021 off-road. No idea where to start but looking for the more simple install and something that won’t break the bank?
    Any ideas? Thanks!
  2. Nov 14, 2024 at 5:02 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    replace the speakers with something decent
    add kicker key amp
    if you're feeling fancy, add a sub. anything from a small powered sub under the seat, to an enclosure behind the back seat and an amp to push it.
    A very basic system that will blow away the JBL system could be done for probably $1200 after tax if you look at holiday sales
    RogerMexico and Bennelson17[OP] like this.
  3. Nov 16, 2024 at 2:58 PM
    RogerMexico
    RogerMexico Active Member
    2011 TURD SPURT
    I’ve been happy with the Kicker HS10 hideaway, if you are considering powered subs.
    If you buy a cheaper amp (like I did - kicker 4x65), the audiocontrol matrix plus will allow you keep your gain down and get nice sound w/o distortion.
    Bennelson17[OP] likes this.
  4. Nov 16, 2024 at 4:30 PM
    trexgrrr
    trexgrrr Well-Known Member
    Replacing the tweeters first will make a huge different. Then get an amp to run the speakers, and one for a micro sub.
