Easiest route for aftermarket audio...
Discussion in 'Audio & Video' started by gromit615, Sep 30, 2015.
  1. Sep 30, 2015 at 9:28 AM
    gromit615
    gromit615 [OP] Well-Known Member
    Eric
    I'm pretty sure I know the answer BUT, I'm gonna ask anyway. Which scenario would be easiest for adding amplifiers, subs, door spkrs, etc. (DO NOT want to replace head unit; remain stock with head unit):
    1. Purchasing a Taco with non-JBL and getting something like a JL Clean Sweep to boost and clean up signal or and then add amplifiers, subs, etc.... OR
    2. Purchase a Taco with JBL upgrade and utilize those pre-amp outputs (they're there, right?) on the head unit and getting rid of all of the other JBL upgrades (except for the head unit; not interested in the JBL amp and sub :puke:) and adding aftermarket amplifiers, subs, etc.?
    My understanding that bypassing the upgraded JBL wiring is a bit of a chore. Would it be easier to go with #1 and just buy the additional components necessary to boost head unit signal?
    Thanks for any input!
  2. Sep 30, 2015 at 3:01 PM
    Flippu
    Flippu Active Member
    Big Island Hawaii
    2015 Blue Ribbon Metallic TRD Sport
    Just depends on your budget. I opted for a plug and play route and it was 1500.00. Im quite happy with the system. It's called OEM Audio+
  3. Sep 30, 2015 at 4:59 PM
    gromit615
    Eric
    Thanks for the feedback, y'all.
    As opposed to a plug and play, I'll be installing JL Audio subs and amps in a custom enclosure.
    Just wondering if it is easier to go non-JBL and use a Clean Sweep to boost the head unit/stock signal OR if getting the JBL head unit and bypassing/removing the JBL sub and amp would be easier.
    Thx again!
  4. Sep 30, 2015 at 5:03 PM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    Define "easier." Either way you're temporarily removing the radio, making a connection (or connections) and putting it back together, yes?
  5. Sep 30, 2015 at 5:07 PM
    stempsons
    stempsons Well-Known Member
    SW WA
    2015 Tacoma TRD O/R 4x4 DC
    TRD Supercharged, TRD Exhaust, TRD Bead Locks, OEM Audio +, Bilstein 6112's/5160's
    OEM Audio+ as well. Easy, and better sound then the OEM JBL system. It operates the same way, but uses better components from what I can tell. Looks factory and utilizes the stock head unit.
  6. Sep 30, 2015 at 5:20 PM
    gromit615
    Eric
    Sounds like my use of "easiest" was a poor choice of terms. My fault. I'm not looking for a quick/easy/simple/5-minute install. I'm specifically checking in on is it a huge hassle to work with JBL wiring when the JBL amp and sub won't be used. Is the wiring hassle worth it just to get the "aftermarket-esque" JBL head unit. Or is it just easier to use a Clean Sweep type component?
    I'm fairly certain that the JBL setup will be a pain in the ass. Easier to go non JBL, plug in a Clean Sweep, and not have to deal with the JBL wiring, I'm thinking...
