Easiest Way to disable DRL on 2009 Taco?
Discussion in 'Lighting' started by Edmund BateTruck, Jan 14, 2010.
  1. Jan 14, 2010 at 5:22 PM
    Edmund BateTruck
    Edmund BateTruck [OP] Member
    Hi everyone, I have 2009 standard Taco, no extras. Daytime running lights are driving me nuts, what's the easiest way to disable them? Is it possible to disconnect/disable them without losing my front turn signals (mechanic said it was impossible since DRL connected to front turn signal lights). I'd appreciate easy instructions/schematics I could show to my mechanic. I have some shop experience, but haven't done much with electrical stuff in a while. Any help appreciated. Thanks!:D
    EDIT: Yes, I did search this topic under the search function and there was no info I could find for a 2009 taco. thanks.
  2. Jan 15, 2010 at 12:19 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    Edit: Read warpwr's post below. This is a much better way. Just add a switch.
    Plus if you remove the DTRL relay and jumper you have to buy a different relay (from the dealer) without DTRL. If you just add a switch to the red/green wire it will only cost you $2 at radio shack.
  3. Jan 15, 2010 at 12:36 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    ^^^^yeap^^^^
  4. Jan 15, 2010 at 1:08 PM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    you should keep them. Ya never know but it could save your life.
  5. Jan 15, 2010 at 1:22 PM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
  6. Jan 15, 2010 at 4:46 PM
    Toyo_Jet
    Toyo_Jet Well-Known Member
    Shane
    Flatlands of Indiana
    10 4X4 V6 SR5 access Cab
    The DRL's don't bother me too much, but I would like to figure out how to make them come on with the headlights and still blink as the turn signals.
  7. Jan 15, 2010 at 4:52 PM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    I might have missed something here, but I think the turn signals are outside the headlights and the DRLs are the same as the flashers...on the inside of the headlights....
    or....am I all hosed up???
  8. Jan 17, 2010 at 6:25 AM
    Edmund BateTruck
    Thanks very much for this. I will talk to my mechanic and see about this. My truck's fairly new and I don't want to void the warranty, so it might have to wait till I hit the 60,000 mile mark, but I appreciate the advice all the same.:D
  9. Jan 17, 2010 at 6:26 AM
    Edmund BateTruck
    :confused: How?:eek:
  10. Jan 17, 2010 at 10:59 AM
    sweetbaboo
    sweetbaboo Well-Known Member
    Northeast
    2016 4WD Double Cab Limited Auto, 2010 4WD Double Cab SR5 6SPD
    I'd like to know as well. I used to have DRL on my previous vehicle (WRX) but don't anymore on my 2010 Taco and feel strange without it.
  11. May 12, 2010 at 11:28 PM
    Fro05
    Fro05 Well-Known Member
    Froilan
    Hawaii, Kauai
    10 SR5 Sport
    Anyone know the part number for the bulb of the daytime running lights? want to change from amber to white...
  12. May 13, 2010 at 3:24 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    its the standard signal bulb....3157. but remember the lense is tinted yellow, so your not going to get a white light adn it will be harder to see during hte day as well...basically not a good idea all around!
  13. May 13, 2010 at 11:25 PM
    Fro05
    Froilan
    Hawaii, Kauai
    10 SR5 Sport
    ohh ok thanks yosh! There are a couple tacomas here running white daytime running lights, and they don't look bad at all...I just hope that they won't burn the housing of the lights if I do change em out
  14. Sep 19, 2012 at 4:14 PM
    three west
    three west Well-Known Member
    JD
    UP MI
    09 DC SB TRD Sport
    hmm, so for some reason I never thought of this before, but I installed a switch to turn off the DRL.
    I could instead just pull out the relay and jumper and use the 8-pin relay instead, right? Then I could go LED w/o resistors...
    why didn't I think of this before?
