Easiest Way to Move the Perch Position on 5100's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JHF4X4, Oct 6, 2023.
  1. Oct 6, 2023 at 8:58 AM
    JHF4X4
    JHF4X4 [OP] Member
    2016 Tacoma SR5
    So I'm here... Trying to lift my Taco a little more. Haha
    Long story short, I would like to move my Bilstein 5100's from setting 3 to 5 (A controversial decision I know).
    My question is: should I remove the shocks again in order to do this, or is there an easier way to move the perch up without having to take the shocks off of the truck? Thanks in advance!
  2. Oct 6, 2023 at 9:03 AM
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    Safest way to do is to remove the shock off the truck. I don’t think you could compress the coil enough to do it on the truck. Plus it would be super dangerous to try.
  3. Oct 6, 2023 at 9:07 AM
    JHF4X4
    JHF4X4 [OP] Member
    2016 Tacoma SR5
    I figured this would be the answer, but I wanted to get other opinions just in case there was a better way. Didn't want to make the job harder than it has to be. If removing the shocks is best though, I can do that. Thanks!
    Xero[QUOTED] likes this.
  4. Oct 6, 2023 at 9:26 AM
    Bishop84
    Bishop84 Well-Known Member
    I’m a flat rate tech and I won’t risk it in the truck. Gotta remove and compress.
    JHF4X4[OP] and RustyGreen like this.
  5. Oct 7, 2023 at 2:03 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    The ride will be the same. Went from the 4th to the 5th and added 285s. In fact it rides better but that may be from the new Toyo AT3s. I have read mixed reviews and people with no experience in doing this talked crap and not knowing first hand. You will be fine!
    JHF4X4[QUOTED][OP] likes this.
