Easiest way to tell if my 2002 PreRunner has Anti-Lock Brakes?
Discussion in '1st Gen. Tacomas (1995-2004)' started by IgoZoom, Jul 17, 2015.
  1. Jul 17, 2015 at 8:44 PM
    IgoZoom
    IgoZoom [OP] Member
    Lake Arrowhead, GA
    2002 Tacoma PreRunner DoubleCab 2.7L, SR5, TRD Off-Road Pkg, Dark Green w/ Gray Cloth, 253k miles and counting!
    Hi guys,
    I just bought a 2002 Tacoma PreRunner DoubleCab from a childhood friend of mine last weekend. He is the original owner and had all of the paperwork for maintenance, repairs and upgrades, but not the sales papers or window sticker to show the exact configuration and options.
    It has the SR5 (w/ Chrome) Package, TRD Package and Power Package and several individual options like Cruise Control, Sliding Rear Window and Tow Hitch (to name a few). The only thing i can't figure out is if it has the optional ABS. Short of slamming on the brakes and potentially locking the wheels (and it can't be too good for the tires either), how can I determine if it has Anti-Lock Brakes?
    Thanks!
  2. Jul 17, 2015 at 8:47 PM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    There is a sensor on the hub. You should see wires running down your knuckle to the sensor
    cruxofthebisquit likes this.
  3. Jul 17, 2015 at 8:49 PM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    If it has ABS, the ABS light will come on and go off on the instrument cluster when you start the truck. Also, check by your upper ball joints. Should see a wire coming up the knuckle to the upper control arm if you have ABS. Lastly, look under the hood. ABS unit will be on the passenger side back towards the firewall. Has a bunch of brake lines routed into it.
  4. Jul 17, 2015 at 8:56 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Have one of these on the passenger inner fender?
  5. Jul 18, 2015 at 4:24 PM
    Yota64
    Yota64 Professional Threadjacker
    Floor it into snowy traffic. Slam the brakes and see what happens
  6. Jul 18, 2015 at 5:18 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    This!!!
  7. Jul 20, 2015 at 6:37 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    That's how I'd check.
    That's the ABS pump. If it has ABS that pump will be there on the passenger fender with (I can't remember how many, 5 or 6) hard brake lines plumbed to it.
  8. Jul 21, 2015 at 9:52 AM
    BiNiaRiS
    BiNiaRiS Well-Known Member
    Portland, OR
    This is the best way. I have an 02 Tacoma that does not have ABS but the rear end is setup for it (abs axles, wiring, etc.).
  9. Sep 13, 2019 at 5:42 PM
    Porthos33
    Porthos33 Active Member
    Eric
    TN
    2002 Toyota tacoma prerunner ext cab
    brush guard, 3" coil spacer lift with add a leaf in rear, Are camper top, k&n air intake, 2 hella ff1000 driving lights
    Very curious to your reply. Why don't you have abs if it was set up for it? Reason I ask is b/c I have that same setup up but I don't believe I have ever had ABS on my truck as the brakes have always locked up even when it was new
  10. Sep 13, 2019 at 6:05 PM
    BiNiaRiS
    Portland, OR
    In 02, ABS was a pretty rare option with most trucks not having it. But it seems like they used the abs rear axles/housings anyways. Not sure if all 02s abs axles/hubs but i'd guess lots if not most do. 03/04 ABS wasn't an option anymore so they all have ABS.
    I just did rear axle seals on my truck last month and ended up having to do 1 rear bearing. All the tutorials call for pressing on a new ABS rotor ring which is a $50+ part. But since my truck doesn't actually have abs, there's no reason to buy a new one and press it on.
    edit:
    If you don't have ABS, but want to know if you have the ABS rear end, you can check to see if you have the port for the ABS sensor (and the end of the rear axle housing will be wider to accommodate the cog wheel inside). the abs sensor goes into the side of the housing and on my 02 Tacoma, there is just a plastic cover there in place of the actual sensor.
  11. Sep 13, 2019 at 6:44 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    ABS became standard equipment on all 2004 models as did the ABS dash indicater light. My 03 has ABS but no dash light.
  12. Sep 13, 2019 at 8:02 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Mine has a spot for an ABS fuse in the box under the hood, but it doesn't have any contacts. Seems like a good way to check.
  13. Sep 13, 2019 at 9:07 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    All E-Locker 8.0” axles are setup for ABS (TRD v6 Models) — even without ABS equipped. None ABS models have a plug on the ABS sensor ports.
  14. Sep 13, 2019 at 9:20 PM
    Bishop84
    Bishop84 Well-Known Member
    Post is from 2015.
    FYI best way in any vehicle is to find gravel on the right side ditch, roll along and brake in the gravel lightly. Any ABS system will trigger on this.
  15. Sep 14, 2019 at 1:31 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The big ugly thing on the right inner fender is a good clue
    Gavingamer901 and Black DOG Lila like this.
