East Bay Mechanic for Engine Rebuild/Replacement
Discussion in 'Northern California' started by slip6, Apr 17, 2025.
  1. Apr 17, 2025 at 3:48 PM
    slip6
    slip6 [OP] New Member
    Picked up a 2.7L 97' 4x4 recently with only just under 150,000 miles. Drove perfect for a long test drive, on the way home oil pressure light came on and I can hear some noise coming from the bottom of the motor. Preparing for the worst, does anyone have recommendations on shops that do good rebuilds/replacements in the Easy Bay area? Thanks.
  2. Apr 28, 2025 at 7:58 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I would use FRANK in Concord. zero doubt. most honest mechanic I have ever met.
    Franks Import Service or something. I live in Santa Rosa now, and on the big issues, I still figure out a way to get my truck to Frank. I think I pass 100 shops that are closer on the way to him.
    Frank and my Dentist...only reason to go to Concord now. :D
    Area51Runner likes this.
  3. Apr 28, 2025 at 7:59 AM
    aficianado
    back to bone stock.
    oh. I forgot. sorry for the troubles.. that is a complete bummer, what you are dealing with.
  4. May 7, 2025 at 7:07 AM
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    https://www.yelp.com/biz/anson-auto-repair-fremont-2
    I had a clutch replacement and a blown headgasket happen around the same time about 7 years ago. I had this Anson auto repair shop do the clutch job and had an engine swap with 150K, swapped out the engine block with blown head gasket rather than rebuild the engine block, new radiator/water pump/etc installed. The engine swap & labor ran me around $6K, but was well worth it.
